Question about RCA HD52W59 HDTV Projection Television
The picture is to big for screen how can i get it to fit if i use the cinima setting it fits but you have the black strip on top and bottom
    Genius:
  • 1,030 Answers
Try this, on the remote push the right or left arrow keys to scroll through formats
Posted on Oct 15, 2010
  • 1 more comment
  • manny8009 Oct 15, 2010
    i have tryed that and that don't work is there any adjustment to adjust
  • Willie Howell Oct 15, 2010
    is the picture stretched? horizonatally, or vertically. i have come across a few in the shop that if the picture s streched horizontaly then it is a bad compnent called a diode that a technician can replace.
  • manny8009 Oct 18, 2010
    it is streched both ways
How do I get the picture to be as big as the tv
The picture is controled by the zoom on the tv remote and on the reciever remote. if you're looking at Wide screen containt the your screen will be black on the top and bottom, zooming will make it fit but you will loose some left and right info. Only HD containt formated for home tv's will, like Oasis, or National geographics, ect will give you full screen. Wide screen is for Movie theaters not TV. This realy sucks but to get a large Wide Screen Picture, You have to buy a supper large tv otherwise, the Wide screen image is small and wide and preaty much anoying with a short wide picture with black bands on top and below..
Sorry. We all have to live with this stuff.
Jun 18, 2012 | Emerson lc220em1
The picture is too big for the screen. the top and bottom is cute off.
You may need to change your resolution. Here are the steps:
  • Windows XP Right Click Desktop and select properties, then click the Settings tab.
  • Windows Vista Right Click Desktop and select Personalize, then on the bottom select Display Settings.
  • Windows 7 right click desktop and select Screen Resolution
Try some different resolutions until your desktop fits in your screen. You could also try moving your screen around with the options built onto your monitor.
Feb 25, 2010 | Toshiba Satellite A135-S2386 Notebook
I need to remove screen protector on my hitachi 65" big screen tv
There is a black plastic strip that fits into the groove at the top of the frame holding the protector and front screen. Pull that down and out (you might need to pry a little to get it started). The attached picture shows the strip partially pulled out at the right edge (photo depicts the top right of a 58K - with a wood cabinet).
Once this strip is removed, you should be able to see a gap (~2mm) between the top of the protector and the frame. Pull the middle of the protector toward you (you may need to hook it with something like a chrochet hook to get it out to where you can get a finger on it). Pull out one side of the protector, then work it loose fromt he bottom. (If it is stubborn, you may have to loosen the bottom frame. Take of the speaker grill, then unscrew the screw on the bottom of the surround for the control panel and pop the surround out. Then there are 3 screws that hold the cabinet frame {might me different for the 58B} and beneath that, 3 screws that hold the bottom of the inside frame. Once those are removed, you should be able to flex the inside frame enough to loosen the protector.)
Installation is the reverse. There are two grooves (at least on my set), and the protector goes in the rear groove(!) (same as the screen itself - first time I tried to put it in the unused groove closer to the front of the screen, and that iddn't work). The black plastic retainer strip goes in the front groove.
Jul 18, 2009 | Hitachi 43F300 43" Rear Projection...
Picture too big for screen
GO TO MENU VIDEO SETTINGS AND RESET TO FULL FORMAT SETTING , GO TO JVC.COM AND DOWNLOAD THE OWNERS MANUAL GUIDE ,
May 16, 2008 | Televison & Video
Removing a screen protector from a Hitachi 50UX58B Projection color TV
There is a black plastic strip that fits into the groove at the top of the frame holding the protector and front screen. Pull that down and out (you might need to pry a little to get it started). The attached picture shows the strip partially pulled out at the right edge (photo depicts the top right of a 58K - with a wood cabinet).ea84b4b.jpg
Mar 22, 2008 | Hitachi 50UX58B 50" Rear Projection...
Picture is vertically too big the heads dont fit the screen?
This answer is generic because I do not know the particular model:
You should call the tech support for your set. This may be a fault in the way the address processing is being performed for the display. Sometimes, depending on the model, the service rep can fix this by re-loading the firmware for the set's operation. I have seen failures in the main drive processor for the screen cause this. The solution was to change the board.
Jerry G.
Jan 08, 2008 | Samsung LN-T4665F 46 in. LCD Television
Please help
keep pressing the button called ARC until you get standard...let me know if it worked
Oct 17, 2007 | Bush 5693D 24" TV
Durabrand 21" tv picture distorted
To properly diagnose this problem,access to the servicer menu will be important.Also,the service literature for the horizontal and vertical circuits may be needed.Contact a tech who can help you that is familiar with Durabrand.
Sep 25, 2007 | Durabrand DU1901 TV
Picture is too big for screen
Go into the setup menu of the TV, and you'll find a category called DISPLAY or ZOOM. That's where you can change the aspect ratio so that it fits on the screen. You'll probably get a gray band on the top and bottom of the screen due to the re-sizing.
Sep 02, 2007 | Televison & Video
RCA HD52W59 HDTV Projection Television Logo
44 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
