Question about GE Microwave Ovens
My microwave has been smoked up inside. - GE Microwave Ovens
  • GE Master
  • 43,501 Answers
Hi, ,.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 16, 2010
Food fire food overcooked and smoked in microwave bad odor and now the food is gone but the smoke odor is left. how do I get rid of the smell now. microwave itself is unharmed thank you, hank
You should be able to get a cleaner spray suitable for use in microwaves. Give the insides a good spray and a good clean, it should take it away. Make certain there is no burnt deposits anywhere.
Apr 27, 2017 | In Microwave Ovens
My whirlpool microwave built in oven emitted smoke
Hi Dagmar
So... you've indicated that your microwave oven has an obvious serious problem.
You didn't have any questions?
The Answer would be pretty obvious anyway!
Cheers
Better Luck with the New One!
FURTHER:
The main component in a Microwave oven is the Magnetron. This generates the microwave energy which is released into a resonant tuned cavity (antenna) that heats the food. Testing the Magnetron would require specialised tools & knowledge. Beside the fact that it would be very dangerous. The Magnetron is often driven by electronics like a switch mode power supply & an inverter. It is possible that the switch mode or inverter has failed and burned out. There can be Electrolytic Capacitors that have failed (leaking or popped) causing the electronics to fail. If you have some expertise in this area then you could open up the unit and inspect for what has failed. Unplug power and never operate the unit while inside. Pull out suspect electronics module's, repair and seal unit up before turning on. The mere fact that you had heated internals is a warning of major problems.
Really, you are better off & safer taking the unit in to a Microwave Repair Technician.
Jul 07, 2015 | Whirlpool Microwave Ovens
When I preheat my samsung Microwave oven, smoke is seen coming out. is that Normal?
Not really, some smoke is sign that some component inside is NOT o.k you must open the microwave and see what going ON. and fix it.
God bless you
Dec 09, 2013 | Samsung Microwave Ovens
Microwave started smoking when i turned it on
Unplug the microwave and take it out check if any food items were present before u put oat meal inside it.IF there in nothing then check for any wire leaks.The smoke may have been caused by leakages in the microwave wire.Check both the things
Dec 07, 2011 | Panasonic NNSD697S Stainless Steel 1300...
Clouds of smoke started coming from the inside of it and we had to put it outside the smoke was coming out of the holes on the inside
It is time to replace the microwave oven, the problem you are describing is one or more issues, the high voltage transformer, high voltage capacitor, the magnetron, and the high voltage diode all play a key roll in generating the high voltage which translates into heating the food. The cost in my view will run high and would be put to better use buying a new microwave oven.
Mar 03, 2011 | Magic Chef MCD1611ST Microwave Oven
Intermittant loud "pop" when starting my microwave
Clean well the inside of the oven, if you keep having the problem and the inside is clean, then the magnetron is starting to go.
Jan 28, 2009 | GE Microwave Ovens
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
Smoke Coming from inside of Microwave even when warming for 10 seconds
Proberly wave guide cover at side it can get grease behind it,And when you used it with small load it tried to cook it and then burned the mica cover,Take mica cover off and try it without it to seeif problem resolved if ok,New cover can be obtained if req.Regards grandadfixer
Oct 10, 2008 | Thermador MBBS Microwave Oven
I would like to know how to clean the inside of my microwave,the wrong cup was put in,and it caught on fire ,and I can't get smoke stain out. Thank you,Molly Dickerson
The smoke stain is almost impossible to remove as smoke tends to get in the pigment of the paint.
If there's a burn smell, you can try simmering a lemon juice and water mixture for several minutes in the microwave. You can also set a plate of charcoal briquettes inside and leave the door closed overnight (DON'T turn the microwave on - just let it sit). Keep the charcoal inside when not using the microwave and it will absorb a lot of the odor.
Jul 17, 2008 | GE Microwave Ovens
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
