Question about Acer X241Wsd Monitor
X241W Acer monitor: getting blank screen. When unplugged and plugged back in, it powers up, stays on for about 10 seconds, then goes blank again. Green power light stays on. Have connected to different pc's; same thing happens. I shone a flashlight on the screen and I can see a dim image. Please help!
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 16, 2010
My monitor won't come out of sleep mode
Try unplugging the power cord from the monitor for 10 seconds and plugging it back in.
Jan 31, 2018 | Westinghouse Computers & Internet
My Acer mnitor won't stay on. The power cord works, when I unplug it from the black power box, hte light that indicates the power supply is working comes on and stays on. However when I plug into the
It is Windows 10.
I have reverted my machine back to Windows 8.1 and its working perfectly.
As long as you haven't had Windows 10 on your machine for 30 days you can revert back to Windows 8.1.
First of all open Settings and click Update and Recovery
Now in Update and Recovery window click on Recovery option. This will open a list of 3 options on the right hand side. You need to look for "Go back to a previous version of Windows" option. To start the process, click Get Started button under this option. It will ask you to plug in your charger before allowing you to continue.
Make sure your battery is fully charged, because before you press the get started button you need to place the cursor over the button and plug in the charger.
Once the screen goes black press the keypad which should then click the button.
Wait a few seconds and then unplug the charger.
All being well the process will now continue without the charger plugged in.
Once you get to the restart screen it should be safe to plug in the charger and you should then still have a screen you can see.
Hope this helps.
Dec 28, 2017 | Acer AL1916W 19" LCD Monitor
My X241w until recently required about 10 or more power ups before it would stay on without shutting itself off. As I was getting ready to replace it I tried setting the resolution to 1980x1080 in...
It may have a lot of dying caps as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/ACER%20X241W/
More damage will be done if the caps get real bad.
The size of this monitor is big but I find the picture quality is not too good.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 19, 2011 | Acer X241Wsd Monitor
No Signal
yes start the computer then keep pressed the key F8 untill the display comes then hightlight the option last good known configuration and select the problem will be solved
Mar 06, 2010 | Acer 22" X223w LCD Monitor
I have an Acer AL1912 that when you plug in the ac, the green power light will blink for about a minute and a half then go solid. The backlight will come on and you can see a faint ghost of vertical lines...
If it is still in warranty call the manufacturer.
if not give more info elah4@zoominternet.net. May be somthing simple like a cable
shutdown computer unplug then disconnect the video cable on the computer from the monitor, plug monitor back in and turn it on, there should be a display that says no video source within a few seconds, if unit is working properly. shutdown and connect video again and then reboot computer. sometimes it just takes a compleat power disconect to reset things,
Jan 30, 2010 | Acer AL1912B 19" LCD Monitor
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Two monitors blank, but on
<table x:str="" style="border-collapse: collapse; width: 124pt;" border="0" cellpadding="0" cellspacing="0" width="165"><col style="width: 124pt;" width="165"> <tr style="height: 14.25pt;" height="19"> <td style="height: 14.25pt; width: 124pt;" height="19" width="165">http://www.wholesaleeshop.com.au/LCD-Monitor/10.4-inch.php</td> </tr></table><br />I wish you problem can be solution. <table x:str="" style="border-collapse: collapse; width: 54pt;" border="0" cellpadding="0" cellspacing="0" width="72"><col style="width: 54pt;" width="72"> <tr style="height: 14.25pt;" height="19"> <td style="height: 14.25pt; width: 54pt;" height="19" width="72">&lt;a href="http://www.wholesaleeshop.com.au/LCD-Monitor/10.4-inch.php"&gt;10.4 inch LCD Monitor&lt;/a&gt;</td> </tr></table>
Mar 24, 2009 | Acer AL2216WBD LCD Monitor
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
ekwhoward@yahoo.com.
Thanks
Ekow
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
X191w blank screen after 2 seconds
Just got off the phone with Acer Suppport. This was after I sent an email to them, that suggested that I call. 8-/ annoying. So the guy on the phone says there is one thing that we can do before sending it in. Unplug it completely for the wall and computer. Hold the on/off button in for 30 secs. reconnect power and the computer. It worked for me
Oct 07, 2008 | Acer X191WSD Monitor
Acer X241Wsd Monitor Logo
787 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
