Question about Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwasher made loud popping noise, immediately stopped and tripped out other applieances, a burning smell came from dishwasher? it had not finished cycle.
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
  • 291 Answers
SOURCE: Dishwasher making loud noise during wash cycle
It's noisy If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
thanks and accept the solution accordingly
Posted on Apr 03, 2009
  • 12718 Answers
SOURCE: My Indesit IDL40 dishwasher, loud bang with slight burning smell but still working?
Any burning smell is not good. Indicates that something in there is too hot and perhaps melting something. Could even catch fire......
Could very well be that whatever is responsible for the noise can be causing the problemo.
Posted on Sep 25, 2015
Sep 25, 2015 | Indesit Dishwashers
Bosh SHY56A Dishwasher - Loud Pop and Smoke While
Hey Matt,
Dishwashers are not that complicated.. Turn off the breaker, pull the machine out - away from the wall..(there will/should be at lest two screws in the top edge holding it to the counter.. remove them first.. then pull it out until you can turn off the water supply.. When you are able to completely remove the washer, you should be able (possibly)to see what happened.. Check to see if the washer arm (inside the washer) will turn, if not.. replace the motor.., check to see if the pump belt will turn?.. it could be the pump drive motor or the pump its self..(remove the belt), then see if the motor will turn, check to see if the pump will turn.
.. White smoke makes me think that the belt was turning and the pump NOT turning..that will cause the belt to smoke.. and smell like burning rubber..If the pump will not turn. you have found t he problem... Also ..Check to make sure there is not a knife or some other object lodged in the drain or pump
NOW -- With all this.. Sometimes REPLACING the machine is actually cheaper than repairing the old one!!! Your wife deserves a NEW one!!
Jun 28, 2017 | Dishwashers
Bosh SHY56A Dishwasher - Loud Pop, Smell of Smoke, Stopped
Resistance burned or the control module shorted with smoke.
Sep 02, 2013 | Bosch Dishwashers
Our dishwasher made a loud pop the other night, and there was a smell of burning plastic/rubber. Since then it has stopped working. No fuse was blown or tripped it seems to be local to the machine. I...
You would probably need a whole new motor but the nwith the smell of plastic you may also have a burn hole in the tub. Your best bet is to replace the whole thing. Sorry
Aug 03, 2010 | Hotpoint 24 in. DWF33 Built-in Dishwasher
On one minute then POP loud noise, burning smell
Loud popping and loss of power is common on plasma TVs and is usually either the Y sustain or Z sustain boards or buffers; in these instances the damaged part will be quite evident.
If this is an LCD you might have degraded insulation on one of the pink/blue backlight power leads causing high voltage to 'arc' to the chassis.
The loud bang and smell is actually to your advantage as in these circumstances the damaged part is usually evident. It'll just be a matter of popping the back off and sleuthing around. :)
May 18, 2009 | Sylvania Televison & Video
Dryer stopped working
The dryers drive belt most likely broke. it must be replaced with a new one.
Dec 20, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Burning smell (electrical) from my washing machine
possibly the suppressor capacitor. take lid off and trace where mains input is connected and that is the suppressor. they sometimes go pop
other possibility is the neon burnt out
Oct 03, 2008 | Smeg WD16BA Front Load Washer / Dryer
Open Questions:
See all Indesit 23 in. DV62 IX Built-in Dishwasher Questions
Indesit 23 in. DV62 IX Built-in Dishwasher Logo
735 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
noel
noel
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
