Question about Kyocera Mita Kyocera-Mita SCANNER RACK Copier
Error code C-6 in photocopy kyocera mita 2035
SOURCE: Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
Posted on May 26, 2009
  • 43 Answers
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Posted on Mar 02, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
  • 126 Answers
SOURCE: KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Posted on Mar 02, 2009
SOURCE: I need to reset ID Code on Kyocera Mita KM-5530
The solution is easy! Push the Default Setting/Counter button on the top right side of the keyboard. Press the the Managment icon on the diplay. Enter 6-4-8-2 on the keyboard and select the Managment icon in the OFF position. Close all windows on the display and you should be ready to go.
Posted on Jun 18, 2009
How do I fix error code C-6 with a KM 2020 copy machine
It is resettable to enter simulation so .....
Press and let down "Clear / Stop", "Start" button on the left to darken or clear, then "Stop / Clear" "U163", "Start" appears "CLE" and there you hit "Start" other time and now.
Feb 22, 2015 | Kyocera Office Equipment & Supplies
Kode error konika photocopy
Defective main PCB.
Energy save communication problem • Communication errors from the communication microcomputer on the main PCB. No communication: there is no reply after 5 retries. Abnormal communication: a communication error (parity or checksum error) is detected five times in succession.
Mar 18, 2014 | Kyocera Mita Office Equipment & Supplies
Kyocera km 2035 has error c-6
The error codes for Kyocera Mita are usually in this format: X-XXXX.
I am assuming the error is C-6XXX so i'm going out on a limb to say it is a fuser error. Check the power source for your copier. Make sure you have a good earth ground. Reset the fuser error. If it does not reset then replace the fuser.
Dec 03, 2013 | Kyocera Office Equipment & Supplies
Ererre c600 km 2035
Are you sure the error isn't C6000, which is a fixing unit error? If it is a C6000 then it maybe able to be reset in simulation mode if the fixing unit hasn't failed. Verify error code.
Dec 23, 2010 | Kyocera Mita RADF-11 REVERSING...
Mita copier error code c63
Fuser error - blown fuse, lamp, or thermistor.
Mar 22, 2009 | Kyocera Mita Office Equipment & Supplies
Problem in Kyocera Mita 2035 MFD
when you send a print job it delivere prints without pressing any button. just try it.
Apr 11, 2008 | Kyocera Mita Kyocera 2035 Earbud Hands...
154 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
