Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Bizhub 350 error code C11AO - Konica Minolta bizhub 350 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,680 Answers
Paper Lift failure of the finisher output tray. Did some one hit the finisher tray or did it hit something underneath? May require resetting the position of the finisher output tray, get qualified tech to do it !!!!.
Posted on May 13, 2015
SOURCE: BIZHUB 350 THROWING CODES C1183 AND NOW SHOWS C5351
Yes, that is it..... The company I purchased the unit from sent a company they use for service out to my house (free of charge)and the finisher needed to be aligned because it was off from the movers who delivered it...It is a fantastic unit...very happy with it.
Posted on Jul 31, 2009
  • 8 Answers
SOURCE: Bizhub 350 error code c2557, how can i fix this?
This code happens if you replace drum without replacing developer. Both must be replaced at same time.
Posted on Oct 22, 2009
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
SOURCE: Bizhub 350 error code EA3226 when trying to scan to email
I changed the SMTP address from a name to an IP and that resolved it for me.
Posted on May 28, 2008
Good day, how do I fix error C11AO in konika bizhub 350?
https://www.manualslib.com/manual/990982/Konica-Minolta-Bizhub-C250.html
Oct 16, 2017 | In Office Equipment & Supplies
I would like a list of error codes for the Konica Minolta bizhub 350
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C350
Apr 14, 2015 | Konica Minolta bizhub 350 All-In-One Laser...
ERROR CODE 0094
no such code for that machine bizhub 350
Jan 24, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 manual de servicio codigo de error el c0500
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350
May 11, 2013 | Minolta bizhub 200 Copier
Error C11A3 Konica Minolta BH 350
solution for error code c11a3 konica minolta bizhub 350 machine
Jul 21, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Sep 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Error Code C-2152 wen i power the machine at begin this messge was apear c-2152
what model bizhub you have, 350 B/W or some other? cant find this code for this machine. sorry
Apr 24, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Apr 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
522 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
