TV will not still powered on. The switch/relay clicks but does not stay latched. For the lasst year it would shut off then after a while 20 or 30 minutes it can be powered back on. Now it will not stay on at all. It is a Mitsubishi VS-50707 rear projection TV
  • 4,889 Answers
The relays clicking means that its a power supply related problem. Checking for faulty caps on the power supply and on the deflection board would be the first thing to try. Look for caps that have swollen or cracked tops(or have tiny holes near the X at the top)
Posted on Oct 25, 2010
  • 11,800 Answers
The problem is caused by aged capacitor - when they used to heat up their internal resistance dropped so low that the current passing thru them got so high it triggered the overstress protection of the power source which shut down the tv. When the capacitors cooled down their resistance has risen enough to allow the tv to start again.
Now some of this capacitors have failed completely and the protection of the power source kicks in immediately after you try to start the tv. The tv must be opened and all the capacitors must be replaced - this is a job that is definitely for a pro. If you're lucky and nothing else was fried when these capacitors failed the cost to repair it will be reasonable - around $250.
Posted on Oct 15, 2010
Samsung TV shutting off by itself and relays clicking
If you don't know what you're doing, don't open it up to fix it!
There are HAZARDOUS voltages on the power supply board EVEN WITH THE TV UNPLUGGED!!! The capacitors can hold a charge for several weeks!
Clicking noise can be coming from bad capacitors on the power supply board.
It's usually easier to just replace the power supply board.
Sep 09, 2016 | Samsung UN55B8500 TV
Dome lites and dahlite stays on after latch is closed
switch on the latch grounded,only comes with a new latch
Oct 14, 2015 | 2004 Dodge Caravan
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
Carlton Microwave - C25MW09. Microwave unit stays on after timer has finished although light goes off and turntable stops rotating. Have to turn it on and off at the mains otherwise microwave unit would...
It is possible that the relay is staying latched to supply voltage to the magnetron even after the timer shuts down. This is dangerous and must be rectified.
You need to check the door switch and the lines from the program timer to switch the relay of the magnetron. It is possible that the timer is faulty and needs a check on the reason why it stays latched unless the power is cut. You can disconnect the magnetron to test but attempt ONLY if you are familiar with high voltage/ electrical circuits.
Jul 09, 2011 | Microwave Ovens
My phillips flat screen keeps clicking like its trying to turn on and wont stop clicking untill i unplug it from the back.. what am i up against ?
The tv power supply board is dead.The the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 19, 2010 | Philips Televison & Video
Mower battery keeps going dead. New battery, new ignition switch, dead in two days. My hour meter stays on even when the ignition is off, so I unplugged it, no help.
There should be a battery relay between the battery and the ignition switch. This relay activates by the keyswitch supplying a feed back to relay while in the on position, causing the relay to latch and powering up the entire electrical system. Chances are this relay has failed in the closed position causing the fuel solenoid and start relay to have power all the time, which will drain the battery in a day or two. A quick fix is to install a disconnect switch on the negative side of the battery which you can shut off when you are done with the machine. Hope this helps.
Jan 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Samsung 50'' Plasma TV won't turn on anymore
If your tv is within the one year warranty period then call 1-800-Samsung for warranty repair. Look at your tv purchase receipt for the Purchase Date. You have one year from the date of purchase to get warranty repair.
Jul 08, 2009 | Televison & Video
Turns on but wont stay on
your start relay in the power supply has burned points and, loses it's connection shutting down your TV turn on the tv with the back off and, listen for the relay click to find it; then replace the relay
Jun 01, 2009 | Hitachi 53UDX10B 53" Rear Projection...
60'' 11 year old Mitsubishi Projection TV
HELLO THERE WE ARE HAVING THE EXACT SAME PROBLEM. TURNS OUT THAT IT IS THE RELAY SWITCH mY TV IS ALSO 11 YEARS OLD. HAD THE SAME PROBLEM 4 YEARS AGO
Jan 17, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
