Question about RCA HD56W66 56" HDTV
Convergence Do you have a picture where this fuse is located
  • RCA Master
  • 5,138 Answers
Convergence next to flyback transfomer has 3 square like caps FL 231 is open most of the time it will cause lost of power as well as convergence.
Posted on Sep 16, 2008
Distorted picture with two pictures of differeny color
When you go to menu then setup do you see convergence? If not then you have a blowed Fuse on the deflection board FL231. If you have convergence in menu then try to adjust .
Deflection Board will be Located on Bottom lefthand side its the board that has FBT flyback Transfomer on it and on the right hand side of the FBT is 3 Fuses in a Roll they are small Brown rectrangler Looking caps but are Fuses it will be the one in the Middle.
Jan 16, 2011 | RCA HD52W59 HDTV Projection Television
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
The picture just changed & the convergence is off with the picture bowing inward on top & bottom of screen & you see the image in red,blue & green. The auto convergence feature in the setup...
U have a soldering iron,solder wick or a desoldering pump,and solders?U know how to do soldering?U can fix this problems like about 20 mins.The convergence fuse part (FL231) is dead.Very common on this model of RCA tvs.U can buy this convergence fuse (FL231) at Ebay.com pretty cheap like $3+ shipping.There 3 small brown or pinkisk sqaure look like caps.The one in the middle is dead.But they're fuses located right side of the Flyback transformer,call a FBT(a big black block of transformer).Resolders the FBT too.
Jun 18, 2010 | RCA HD52W59 HDTV Projection Television
Picture looks like hour glass.
You're probably talking about bad convergence. Probably Convergence power board. Only $20-$30 from encompassparts. com, if still available.
Apr 17, 2010 | Televison & Video
Bowed picture. Red,green, & blue lines around picture
Go to menu setup look for Convergence,see no Convergence.U have an open Fuse(FL231)located right side of the Flyback Transformer.
There is 3 in a roll small brown rectangle looking caps,but they are fuses,it the middle one is dead.
Aug 23, 2009 | Televison & Video
The picture looks double with the red convergence adjustment will not work took back off all color lights seem to be working
Go to menu setup look for convergeence,see no convergence adjustment.U have an open Fuse at (FL231)located right side of the Flyback Transformer.There is 3 in a roll small
brown rectangle looking caps,but they are Fuses,it will be in the one in the middle.
Aug 20, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
RCA model P61950
fl231 is the convergence fuse, and is soldered to the board in proximity of the convergence ICS, on RCA rear projection TVs.
If
fl231 has blown, TV usually does not turn on at al, if you get bowed picture, that means that the convergence ICs must be replaced.
The fuse is on the same board where you find convergence ICs, if the fuse had blown, or the pico fuses at the base of the STK convergence ics had blown, the STKs must be replaced.
There is need of purchasing the service manual to do the job.
The repair shuld be done by a technician.
This is the convergence IC, model may vary:
Dec 13, 2008 | Televison & Video
RCA 52 INCH CONVERGENCE PROBLEM HELP/already replaced the fl231 fuse
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence concern
They are located right next to the Convergence ICs easy to spot. There are numerous identical resistors.Usually 1 or 2 will be open.
Feb 10, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Tv not powering up
Check micro fuses in power supply,Ex. F851,F852,etc.
Common cause is convergence IC's are bad,located on large heat sinks.let me know....T.
Oct 23, 2007 | Toshiba TW40F80 40" Rear Projection...
RCA HD56W66 56" HDTV Logo
82 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
