Question about Mabis Automatic Digital Blood Pressure Monitor 04 206 001
Monitor starts pumping but comes up with an HI almost immediately and then goes inti an Er1 The batteries are new It is model# 04-244-001
  • 11,800 Answers
The air pressure sensor from the bladder is defective - it will be cheaper just to get a new tension reader than to try to fix this one.
Posted on Oct 15, 2010
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
Hi my xv 1900 yamaha wont start up have tried a replacement battery still not working it has an error code ER1 can anyone help
yamahas over a period of time have a known name for wire shorting so have you wire harness looked at
Oct 08, 2013 | Yamaha 1900 XV 1900 A Midnight Star
My Beko DW686 Dishwasher displays ER1 Error Code, there are no error codes in the manual, can you help?
reset error code 01. pulled dishwasher out removed kick plate tipped at 45 deg angle and found no leaks or water. turn6ff59c77-7c20-45c4-ac2a-e3c9e6fd4c14.gif breaker off and back on after 20 minutes still doesn't clear.
see tje diagram attached. God bless you
May 25, 2013 | Dishwashers
My truck wont start !
Have you checked the fuel pump relay and the EEC relay for power and a ground signal from the computer ?
The fuel pump relay should send power to the pump for 3 seconds when you turn the key on.
May 13, 2013 | 1988 Ford Ranger
My 2002 r1 is showing code er1 and speedometer stays at 0
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Er 1 and Hi temp problem
Yamaha Fault Codes motorcycle manuals
https://r1videos.files.wordpress.com/2011/04/2002-2003-yamaha-r1-service-manual.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Dec 06, 2012 | 2002 Yamaha YZF-R1
Out of nowhere we get cracking it just started happening went on all night. tried everything figured we needed a new monitor got a new one and its still doing it help we love this monitor
Sounds like interference if its battery opperated try switching of your house electricity to see if it goes away, if it does turn everything back on one at a time until interference comes back, then by process of elimiation find the culprit.
I would be looking at items that use any sort of radio frequency, wireless devices, cell phones and wireless house alarm if you have one.
If monitor uses a power supply try batteries instead to see if that makes any difference, try a different power supply.
Sep 29, 2012 | Sony 900mhz Baby Monitor
Starter motor went out on 92 5.0 ho replaced it and new battery, now fuel pump does not work I get a 542 code checked fuel pump relay and inertia switch both good fuse good
  • Code 542 indicates one of the following conditions:
Engine Starts:
· Fuel Pump secondary circuit shorted to power
· Fuel pump relay contacts always closed
· Open in fuel pump monitor (FPM) circuit between ECU and connection to POWER TO PUMP circuit
· Heated Exhaust Gas Oxygen (HEGO) sensor shorted to power
· faulty ECU
Engine Does Not Start:
· Open inertia switch or inertia switch circuit
· Open in or between ECU and fuel pump (This includes open in fuel pump brushes/windings)
· faulty ground connection at fuel pump
The easiest way to check this circuit is to go to the fuel pump relay. If the relay clicks when the key is turned to the "RUN" position, then the inertia switch circuit is ok.
The Pink/Black wire starts from the fuel pump relay and goes two directions. One side goes back to the fuel pump. The other side is the fuel pump monitor circuit and goes to pin #8 at the ECU. This wire should only be hot for a second or two when the ignition is turned to the RUN position.
The fuel pump relay receives power on the Black/yellow wire. It comes from a fusible link at the power distribution center. This wire should be hot at all times.
If all the above is working as designed, them you probably have a bad fuel pump.
Feb 13, 2011 | 1992 Ford Thunderbird
My i-one screen comes on when I start up, but immediately goes blank. Then when windows starts it comes on then immediately goes blank. The external monitor works.
this usually indicates the circuit in the LCD has gone bad, I hope that's not the case, but more than likely it is. Sorry to be the barer of bad news.
Oct 31, 2009 | Computers & Internet
I got a leapfrog click start my first computer
yes there should be two parts. First there is the actual computer and the second is the base (where the games are connected to). The television should be set where you would usually watch a dvd/or play  a game(depending on what model tv) the computer is wireless so you can use it from the sofa etc. but you must have the base in order for the game to work. I just purchased one and my son loves it.
Mar 08, 2009 | LeapFrog ClickStart Educational Software:...
Acer AL2017 20 inch LCD Monitor comes on for 2 sec during start up then goes black. I 've had it for a year now. During start up it comes on 2 sec goes black then as the start up continues comes on 2 sec...
Hi
I repair monitors
Based on other models , it sounds like you are having a powerboard-inverter issue.
It just so happens that I hjust got one in that's doing that, I should know in a day or two (maybe sooner) what the whole story on this model is.
Good timing !!??
ebaysbammbammfran
Oct 14, 2008 | Acer AL2017 20" LCD Monitor
Mabis Automatic Digital Blood Pressure Monitor 04 206 001 Logo
63 people viewed this question
Top Mabis Health & Beauty Experts
Dan Webster
Dan Webster
Are you a Mabis Health and Beauty Expert? Answer questions, earn points and help others
