Question about MagLite Camping, Backpacking & Hiking
Keeps blowing new bulbs - MagLite Camping, Backpacking & Hiking
  • 283 Answers
Since this is a simple construction flash light (no electronics) make sure you are installing the correct bulb for the voltage of the batteries.
If you use a bulb that is for a 2 cell (3.0 volt) in a flashlight that takes 4 cells (6.0 volt) the bulb will burn out every time.
Posted on Nov 02, 2010
My Neff oven keeps blowing bulbs, immediately a new bulb is fitted it blows like a fuse.
Maybe your First bulb in the oven is a 220 volt bulb not a common 110 bulb? Good luck.. BCB...
Oct 23, 2016 | Neff Ovens
Have a brand new jonway 50cc 15 miles blew bulb whats wrong
Occasionally bulbs will fail for no reason. Replace the bulb and try again. If it fails again, then you likely have a problem.
May 23, 2016 | Jonway Motorcycles
CTSY fuse keeps blowing
ok have your replaced any bulbs? i have found putting bulbs in wrong or just being a bad light bulb can blow fuses. try replacing all bulbs with new ones. its cheap and it could be the problem
Mar 18, 2013 | 2008 Chevrolet Silverado 2500HD
My 6d maglite keeps blowing the bulb
6D Maglite? As in 6 D cell batteries?
1-1/2 Volts (Each battery), times 6 = 9 Volts.
Using the proper bulb?
The original is a Krypton bulb. (No, I didn't make the name up)
http://www.toolup.com/maglite_lmsa601_mag-num-star-6d-relacement-bulb.aspx
http://www.batteryjunction.com/maglite6c.html
Guess what happens if you put a 3 Volt bulb with 9 Volts?
Regards,
joecoolvette
Nov 27, 2012 | MagLite Mag-Lite& Flashlight
Fuse keeps blowing out..
if fuse keeps blowing this would indicate a short in the wirers somewhere running to the lights.....
Aug 22, 2012 | 1999 Lexus Gs 400
Headlight keeps blowing out 1996 yamaha virago 1100
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Headlight globes keep blowing
Yamaha Virago XV535 1100 1981 1994 Service Manual
OEM parts for Yamaha
Yamaha Virago XV1100K Owner Manual
Jul 22, 2012 | Yamaha Motorcycles
Metal lamp keeps blowing bulbs
Call or write Oceanic Systems. Their information is available at the following address:
http://www.oceanicsystems.com/contact/
May 23, 2009 | Coralife Zilla Aqualight Power Center
Camping, Backpacking & Hiking Logo
622 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
John Egan
John Egan
David Black
David Black
Level 1 Expert
 steve
steve
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
