Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag Washer will not spin
Our Maytag washer will not spin, everything else works but when it goes into the spin cycle it starts to smell like something is burning
  • 3 more comments
  • Anonymous Jun 10, 2008
    The smell was like burning rubber.  Husband eplaced the two belts, but it still will not spin.  Is there a reset button?
    angie
  • Anonymous Dec 22, 2008
    everything works except spinning, does not smell like its buring
  • maryhg5100 Dec 22, 2008
    everything works, except it doesnt spin, and doesnt smell like its burning.
    it seems like the agitator on bottom is stuck.
  • EDWINS114 Feb 04, 2009
    WVERETHING WORKS EXCEPT SPONNING SMELL LIKE BURNING RUBBER
  • billypix Mar 08, 2009
    I have a maytag mav6451 washing machine .. when you turn the machine on water goes in then when the spin cycle comes on will not spin ? no belt smell at all.. almost like it must have a reset somewhere .. we had to move it two feet to have a shelf moved thats when this problem happened.. wierd please help thank you..
  • 246 Answers
Pull the unit forwardand lean it back about 45 degrees. You'll have to play with it a bit, but once it's far enough out, it will lean back without you having to hold it. Remove and inspect the belt(s) are they in good condition? Next, check the pulleys (wheels) underneath. Do they turn? One is for your pump, one is for your transmission and one is for the motor. (in case one doesn't turn, you'll know what portion needs to be worked on). Also check the track on your pulley the belt sits in. Is it dammaged or worn?
Posted on Jun 16, 2008
  • 27 Answers
Had the same problem with mine. Check for a thin washer ate the bottom of the transmission rubbing against the pulley. If it is the the transmission will have to be replaced.
Posted on Jun 18, 2008
Can agitator be removed
Posted on Dec 22, 2008
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Clothes are sooaking wet when cycle finishes and they smell bad
The wetness is due to the spin cycle either not working properly or not being allowed to finish. For the smell, with the washer empty, run a cycle on hot/whites with bleach only, after the first cycle drains, open the washer and add more bleach directly into the washer.
Apr 20, 2009 | Maytag MAH6700AWW Neptune Front-Load...
My washer makes a loud noise during a normal wash cycle.
If it is a belt driven machine, then there's the smell. Lean it back a little, enough to fit a paint can under 1 corner and you can feel the belt right on the bottom. Feel for cracks, flat spots or a lot of black dust. Remove belt and make sure everything that it goes around spins free.
Mar 17, 2009 | Maytag PAV2300 Top Load Washer
SPIN CYCLE WON'T START UNLESS DRUM IS MANUALLY STARTED
YOU NEED A NEW COUPLING THAT GOES BETWEEN THE MOTOR AND THE TRANSMISSION...IT'S ABOUT A $20 PART.
Mar 13, 2009 | Maytag PAV2300 Top Load Washer
Loud sounds coming from the washer on spin cycle
That is a characteristic of bearings gone bad. You should look into replacing the bearings.
Mar 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Jul 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
1,431 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
