Question about Chariot Carriers Inc. Chariot Carriers Cougar 2 Stroller Trailer Chassis Color ORANGESILVER
Last winter in -40'c weather the clear plastic side panel cracked. Is there a way to repair this?
    Problem Solver:
  • 8 Answers
Try the product named bondo that you can get at most auto stores. be sure to follow the directions. if you dont care how it looks than apply to both sides.
jim
Posted on Oct 16, 2010
We don't the maintenance book - what kind of oil does a 1998 Plymouth Neon take? Thank you
Very cold climate/weather, I'd run 5 w 30. Warmer/hot weather 10 w 40.
Here is Southern Ontario Canada, I run 5 w 30 or 10 w 30 winter and 10 w 40 summer.
Apr 10, 2011 | 1998 Plymouth Neon
What type of tires would you recommend for winter driving?
latitude-x-ice.jpg Latitude® X-Ice®
Winter
Winter Tires
Better Starting Grip in Icy Conditions.
A special Winter Flex Compound, specially formulated to maintain its grip under the most extreme cold-weather conditions, including snow and ice, to help deliver better starting grip and shorter stopping distances.
Better Traction In All Winter Conditions
Cross Z-Sipes Technology uses a specially designed curve that locks the sipes in place, helping to provide improved grip on snow and ice. And because the sipes are full-depth, their grip lasts winter after winter.
Quiet, Smooth Ride in Cold-Weather Conditions
Dec 02, 2010 | 1996 Jeep Grand Cherokee
Cracked screen on 32 bravia. can it be fixed
If just the plastic screen is cracked, and it hasn't affected any of the LCD screen underneath, you could take a stab at removing it.
I would not recommend it, though. In order to access that panel, you have to remove the back, remove the boards and free up the panel. As it is, the LCD panel is one sealed piece, and getting at that sheet of plastic would be nightmarish.
Now, if by cracked you mean that you have cracked areas of the screen, showers of pixels, whole swaths of black and white and other colors. You know, that kind of beautiful sparkle that can only be made by the flying WiiMote, then you need to replace the LCD panel. And for your 32"--given the cost of replacement--the repair would not be worth the expense.
Jan 21, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
What oil viscocity for honda accord DX 1990 for cold weather ?
5W- 30 is the lowest you can go in winter time. I would use a high mileage formula since we're talking about a 1990 honda. It will help condition the seals in the motor from making any oil leaks worse.
Nov 16, 2009 | 1990 Honda Accord
95 jeep grand cherokee, hard starting, backfires, when cold
get a couple bottles of gas line antifreeze .. if you don't already use it and add it to the gas.
Robert
P.S. in minus 40 i don't even get out of bed... minus 23 here last nite... isn't winter grand
Jan 21, 2009 | 1995 Jeep Grand Cherokee
My 1999 Ford F150 Heater only blows out cold air
guys have you checked for a vaccum leak????? there is a little plastic ball with a vaccum line going to it that controls the outside air coming in. check for a leak in this line
Dec 10, 2008 | 2001 Ford F150 Styleside SuperCrew
Melted hole in side of rubbermaid stock tank
there is a product called all plastic
i have had my best luck with this product
Nov 29, 2008 | Garden
Plastic radiator repair
I doubt you can actually fix it "yourself", but you can save lots of money by taking it to a radiator shop instead of buying a used or new radiator. They can replace the plastic tank for the bad side, but it is usually the drivers side because this is where the hottest water exits the engine and causes the plastic to crack. I removed the radiator myself and took mine to a shop and they repaired it for $40........cannot repair yourself because the tank has to be crimped on!!!! And radiator "stop leak" products will not work because they are for metal tanks!!!
Nov 21, 2008 | 2001 GMC Jimmy
Replace exterior driver door handle
If you remove the inner door panel of the door there will be plastic weather shield covering most of the door. Use a hair dryer or heat gun to heat the weather shield up and slowly peel it away. There will be 2 (10mm I believe) bolts on the inside of the door panel to release the handle (have someone catch it from the other side). To re-install simply connect he handle rod and 2 bolts then place the door panel back on and your done. A word of advice is be gentle with the door panel so not to damage the door pins or crack the plastic. Taking your time can be fun when learning a car ;).
Jul 03, 2008 | 2000 Toyota Corolla
Chariot Carriers Inc. Chariot Carriers Cougar 2 Stroller  Trailer Chassis Color ORANGESILVER Logo
91 people viewed this question
Top Chariot Carriers Inc. Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Chariot Carriers Inc. Baby Gear Expert? Answer questions, earn points and help others
