Dear Expert I have Maxtor 250GB hard drive with usb and e-sata connections. I can't see the drive, in my computer, But i can see when i Choose my computer then manage and then storage but i cannot format the drive I am using OS Windows Vista Home Premium with 1.86MHz processor, 1.49 RAM with 120GB harddrive.
  • 3 more comments
  • Yatisme Jun 02, 2008
    I have tried, using different enclosures but had the same problem
    I have describe the problem above, to give you more understanding of this problem, I have taken print screen of this page. I hope its helpful
    I have tried using maxblast 5.0 but still no luck, from the picture you can see i cant format the drive, as system does pick up the drive
  • Yatisme Jun 03, 2008
    I have done, what you told me to do, but the problem is even worse, I have manage to install windows XP in one of my partition, but as soon as i follow step to format the drive which is my computer then manage then storage i cant go beyond that point. it just stops with no error anything.
    The another thing, i found was, i can see maxtor SATA drive in bios, but i cant boot from that drive, as it doesnt contain OS
    After uninstalling windows XP OS, the hard drive is making some different noise sort of cringe (not sure of spelling).
    Genius:
  • 3,422 Answers
If you have another PC/laptop with xp please try formating in that.
Try using MaxBlast 5.0 for Windows vista.This software will help you to partition and format the drive.Please CLICK HERE
Goodluck..
Posted on Jun 02, 2008
  • Priya darshan Jun 02, 2008
    Please don't forget to rate or accept the solution.
    ok so you've already tried using the maxblast 5.0 and still no luck?And is the problem same with xp?
    Sergeant:
    Champion:
  • 256 Answers
But windows xp home, xp pro, vista home etc... don't need drivers may be problem with usb cable or case....
  • After you plug in usb hdd boot system with windows xp bootable cd and make partition in windows setup after you make partition exit setup...
    Hope that helps! Should you have any further questions, please post them here.
    If you are satisfied with my solution or have no further queries, please take a moment to "Accept" this solution.
    Thank you for using Fixya!
    Atiqq
I need driver for diamondmax 21
Turn the computer off.
Turn the computer on, and press <DEL> to enter BIOS SETUP.
Ensure that the hard-drive is "enabled", and set to 'AHCI'.
Save the BIOS settings.
Reboot, and install Windows.
May 03, 2015 | Seagate 250GB Maxtor DiamondMax Plus 21...
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
I AM LOOKING FOR LATEST DRIVER DRIVERS FOR MAXTOR DiamondMax 21 SATA 250GB Hard DRIVE FOR WIN XP-PRO PC
The latest drivers and support would be available from the Seagate website. The Seatools utility is an excellent tool that is also available.
http://www.seagate.com/www/en-us/
I hope this helps.
Sep 03, 2011 | Seagate 250GB Maxtor DiamondMax Plus 21...
Sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
