Question about Krups Bravo Plus 872 Espresso Machine
There is a relay or control module. It has failed. I have bypassed the the middle prong, so power is on whenever the cord is plugged in. Where can I find the parts number for this part & where can I buy it. Thanks Scott
  • 26 Answers
If you need the control module you will have to go to Krups. If you just need a relay I recommend Norvac. You can bring most any electrical component in and they can match it. I just found out they are only in my area. You can also check Radar Electronics and you could get lucky at Radio Shak. I hope that helps a little. you could also send me a picture of the relay and any numbers that are written on it.
Thanks, Mike mikey@espressomachineexperts.com
Posted on Oct 15, 2010
Golf diesel 2003 keeps stopping randomly no diagnostic faults logged
When you say shopping you mean Stalling right. If yes then the usual cause is a failing Relay 109 which is the main power relay . The early golf had a grey relay which failed due to dry solder joints etc the modified black relay was issued to elevate the issue.
Relay 109 supplies power to these ,
Glow plug relay
- Fuse 32
ECM
Fuel quantity adjuster
- Fuse 34
Cold start injector
Waste gate bypass regulator valve (N75)
Change over valve (N239)
EGR vacuum regulator valve (N18)
Mass air flow sensor (G70)
- Fuse 43
Clutch vacuum vent valve (if equipped)
Brake vacuum vent valve
Relays for preheating coolant (if equipped)
Crankcase ventilation heating element
The ECM supplies power (and sometime ground as well) for:
Fuel cutoff valve
Cruise control switch
Manifold (intake) air pressure/Intake air temperature sensor
Needle lift sensor
Engine speed sensor
Engine coolant sensor
Closed throttle position switch (part of "go" pedal)
Kickdown switch (part of "go" pedal)
Throttle position switch (part of "go" pedal)
Fuel temperature sensor
Modulating piston displacement sensor
The ECM also communicates to the instrument cluster electronics and transmission control module (on automatics).
As a result of this, you can see why if the relay starts to cause power to flicker, or voltage drops, for all of these components, the results can be "unpredicatable" and none of them desireable.
Sep 26, 2016 | 2003 Volkswagen Golf
Lights will not turn on
I experienced the same problem. One day the lights on the unit weren't on. The wall outlet that the dishwasher uses had power because the Garbage Disposal that also uses the same outlet had power. Turns out the power supply cord also tied to the water supply hose and had over the months (due to the constant slapping or dancing of the water hose whenever the electrically controlled water valve was opened or closed), had caused the female receptor prong inside the wall outlet to loose continuity with the male prong of the dishwasher power cord. It might have been a defective wall plug all along but the wall outlet worked for months before the problem arose. Anyway, after replacing the wall outlet the dishwasher again has lights and works fine.
Mar 06, 2015 | KitchenAid Dishwashers
How to connect power cord
Hello Jake. It depends on whether or not you have a 3 prong cord (3 wires), or a 4 prong cord (4 wires). So I'll just tell you both.
For Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case
wrightly_3.jpgHere is an example of a 3 prong cord for a whirlpool dryer. If your terminal block has 5 screws, you still do it the same way as stated above. these wires are not colored. You should have a strap in the middle that is connected with the middle wire. Sometimes there is a wire attached there instead of a strap.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Here's an picture to use as an example;
wrightly_4.jpgJust be sure to use the strain relief at the opening where the power cord first enters the dryer. It will help secure these connections against being pulled loose or cut on the cabinet, and that could pose a risk of you coming close friends with 240 volts. Not a friend I want to have.
I hope this is helpful,
If you have any questions, feel free to ask.
thanks for using fixya
Mike W.
Aug 12, 2011 | Whirlpool Dryers
I need to switch the power cord from a four prong to a three prong. The three prong that I purchased is a 30 amp. Will it be sufficient? Only one of the strands on the three prong is labeled. The...
30 amp. will work just fine...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Feb 06, 2011 | Dryers
Switched chords on dryer from four prong to three prong when plugged in the top left prong sparked did i fry my dryer or is this fixable?
This is probably fixable as you probably hooked the cord up wrong and it arced and likely blew the breaker before much was damaged. The 3 prong cord has obviously, 3 wires. As long as you get the middle wire in the the cord hooked to the middle terminal on the dryer, the other two wires can go to each of the outside terminals, no matter which one goes where. Correct the cord and you will probably be in good shape.
Sep 16, 2010 | Dryers
Don't know how to switch from 4-prong to 3-prong power supply
Your new 3 prong power cord needs to be wired up just like the 4 prong you just dont have the seperate ground . in the use of a three wire cord ground runs thru neutral .Hook black to black on the terminal block on unit. hook red to red on the other side of block and white to white or green in the middle reinstall the cover ....Plug in and your ready to dry
Aug 14, 2010 | LG DLE2532W Electric Dryer
Hi, have a magic chef MCWC16MCG. I plugged it in to a a receptical and it wasn't working. Due to limited space I used an extension cord and a 3 prong adaptor (live and learn) so I could get it to a...
the extension cord must be # 12 wire size for better and the gorund should not be removed . ( proper polirty is important . ) do replace the start relay and if you have a ohm meter ck it for open or short to ground before installing the relay . ( good power is best ..or a short compressor life is for sure .. mm
Aug 11, 2010 | Magic Chef MCWC16MCG Wine Cooler
Power cord hook up
Hi Jay
Middle terminal is White and goes to the "L" shaped prong
Red and Black go to the Flat prongs (Doesn't matter which)
Round prong to cabinet Ground.
There may be a strap from the White lug to the cabinet. This must be removed for the 4 prong plug arrangment.
Eric
Jun 08, 2009 | Electrolux Dryers
Can I install a 3 prong dryer power cord versus a 4 prong one and will it work?
yes,is your wall plug 3 prong?remove the small cover off the back of the dryer,you will see 3 screws,remove the 4 prong cord,all you have to remember on the 3 prong is the middle wire on the cord goes to the middle screw on the terminal block, mount the other 2 one on each side and your done,let me know how you do-mike
Apr 21, 2009 | Dryers
Have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
Mar 28, 2009 | Whirlpool Dryers
Krups Bravo Plus 872 Espresso Machine Logo
98 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
