Question about Radware LinkProof Application (904627-cl3) Networking Switch
We have 3 isp load balancing through our link proof. Every 2 minutes, it shifts to one of the other isp. That is causing a problem with site that have to connect for a longer time. There must be a default idle time setting in linkproof. How do I set the default idle time to 1 hour?
Easy - get an Elfiq. We use that and it plain works great.
Posted on Oct 16, 2010
Washer wont spin or agitate and when set to drain and spin immediately starts making a noise and doing nothing with lid closed or open. what could it be?
Sounds like a load out of balance. Try shifting the clothes then press the spin cycle. Sometimes unplugging the washer for a minute or two resets the timer. Are you over-loading with heavy items?
Feb 08, 2015 | Washing Machines
D-Link DI1705B configer
I have two internet connection, each with 4mbps bandwidth. I want to join/merge both of them to get 8mbps speed, both routers have WLAN and LAN capability.
1-How to Double my speed using two routers.
2-Can I bridge two routers in Windows and double my interent connection speed?
3-Any download manager that accepts two internet connection to download.
Dec 19, 2013 | D-Link Computers & Internet
SPEED IS LOW
1-DO SOME CONNECTION SPEED TEST (MAKE AN ACCOUNT TO SAVE YOUR TESTS)
2-CONTACT YOUR ISP .YOUR ISP WILL CHECK YOUR SPEED THAT YOU PAY FOR AND DO ALL CONFIGURATIONS.IF THEY NEED PROOFS THEN GIVE ALL YOUR IMAGE ADDRESS TEST ON THE SPEED TEST WEBSITE.
post back!
Apr 20, 2013 | D-Link DI 514 Wireless Router (DI-514)
My Kenmore Elite Oasis top load washer will start when is ready. We press the start button several times and hold it down for minutes at a time then maybe it will start. Plus even the smallest load will be...
If the washer is shaking and actually going out of balance and generating the UL error and the drum is empty the most likely cause of this problem is something under the spin basket.Clothes can end up under the spin basket and cause it to turn crocked and cause the out of balance. First I'd recommend removing the spin basket and check under it for any clothing or other obstruction that might cause the out of balance. Here is a diagram of how to Check.. Click Here
May 22, 2011 | Kenmore Washing Machines
Fav6800aww machine wont stay balanced move the clothes around it starts back up for about one minute then stops code comes up dc thanks earl
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
In that Sticky I discuss what is the cause of DC or UC unbalance errors and the fix.
Apr 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Internet extremely slow on one network, fine on the other
Not knowing if this relates directly as i am not from Australia but have you checked with the ISP.
The phone line providing the internet access may be damaged in some way or require calibration to reduce line noise (which can cause slow speeds).
Alternatively, have you got a usage limit that you may have reached. ISPs have the ability to throttle back your connection speed.
Thanks
Dec 22, 2009 | D-Link DSL-G604T Wireless Router
Comes up with the sign UE ??
Hi
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | LG WM-2277HW Front Load Washer
Pix 515E inside to outside translation problem
Dear Kiran,
What is the name assigned for isp 1 as well as isp2.
for your reference kindly find the sample configuration......
ISP 1:
interface ethernet 0 100 full
nameif outside security-lvl 0
ip address outside 203.193.129.132 255.255.255.240.
nat (inisde) 1 (local network)
global (outside) 1 203.193.129.133
route outside 0 0 203.193.129.129.1.
regards,
mani.S
Mar 09, 2009 | Cisco PIX 515E Firewall
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
Nov 09, 2008 | Whirlpool GHW9400 Front Load Washer
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Radware LinkProof Application (904627-cl3) Networking Switch Logo
162 people viewed this question
Top Radware Computers & Internet Experts
David Payne
David Payne
Are you a Radware Computer and Internet Expert? Answer questions, earn points and help others
