Question about Vizio L37 Television
Vizio p42 very dark screen backlight off
I cant see the backlight shining through the slots in the back, picture is faint and blurry after black liquid goes away.
How do i turn on, or fix backlight on plasma tv?
  • Anonymous Mar 29, 2014
    No backlight seen thru the back of the TV.Can I buy a replacement part for the backlight ?
    New Friend:
  • 56 Answers
There is no back light in plasma TV, Base on the description, the Z Sustainer board is bad. Replace the board will fix the problem.
Posted on Feb 17, 2009
I have a Vizio E421VA LCD HDTV and am getting a black screen. The power light comes on, but am still getting a black screen. Does anyone have the same problem and/or solution?
To determine if the backlight driver or the T-Con board is the problem, di this. With the TV on shine a flashlight on the screen. Look for a faint picture. If you can see one then the backlight control board is bad. If you see no movement or any picture at all, the T-Con board is bad. You can get the parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Oct 17, 2017 | The Video Game Consoles & Games
No picture, sound works good
Sounds like a backlight fault. Dim the lights in the room and turn on the set. Shine a bright flashlight on the screen, you should see a faint picture. If you do, you have a backlight problem
Oct 28, 2013 | Vizio Televison & Video
I have had my 55" Vision for a year and a half. Today I was watching a movie and the picture went dark and audio stayed on. If I turned the TV off and then back on it would light up with no Vision logo...
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. If you see a faint picture, you either have a back inverter or a bad backlight bulb.
Sep 02, 2013 | Vizio GV42L 42 in. LCD Television
I have a vizio 42 inch model VO420E serial# LUKECAK1409419. when i turn it on i get a black screen but i have audio. it does this in every input. what can i do to fix this problem?
Most likely you have a backlight problem. To verify this, dim the lights in the room. Take a bright flashlight, turn on the set, and shine it on the screen. If you see a faint picture, you have a backlight fault. Your backlight inverter may be built into your power supply board. If this is the case, you will have to replace the inverter/power supply board
Sep 01, 2013 | Vizio Televison & Video
Dp32648 picture goes black, tv stays on with sound.
Dim the lights in the room, turn on the set and shine a bright flashlight on the screen. Do you see a faint picture? If you see a faint picture, you have a backlight fault. Could be several things, you could have a bad backlamp, defective inverter, defective 24vdc power supply, or a faulty main board. I would highly recommend you get a diagnosis
Apr 05, 2013 | Vizio Televison & Video
Black screen with sound
Turn on the set, dim the lights in the room, shine a bright flashlight on the screen. If you see a faint picture, you most likely have a fault in the backlight circuit. Are you wanting to repair this yourself?
Mar 07, 2013 | Vizio VO47L 47 in. LCD TV
When I turned on my vizio vo37om this morning, there was no picyture, screen is black. Sound is fine
Dim the lights in the room, turn on the set. Shine a bright flashlight on the screen, do you see a faint picture?
Feb 11, 2013 | Vizio VO370M LCD TV
Why does my Vizio E470VLE LCD TV have no picture but it does have sound?
you may have a backlight problem. To verify this, dim the lights in the room. Turn on the set and shine a bright flashlight on the screen. If you see a faint picture, you have a backlight fault.
Jan 21, 2013 | Vizio E470VA 47 1080p 120Hz LCD HDTV
I turn my tv on but the screen stays black
inverter board is probably bad. use a flash light to shine on the screen...if you can see a faint picture then the backlight board is bad.
Sep 22, 2010 | Vizio VO42L 42 in. LCD TV
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
Vizio L37 Television Logo
1,337 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
