Question about GPS
My Nordic NS1074 car starter will not start car. The light is flashing but the "clicking" does not happen and therefore cannot turn on car with remote. My car is a standard and I leave it in neutral with handbrake on. Was working last winter now not. The door locks will work though - they were installed separately but use both remotes. I wish to have advise on what happened and how to fix or where to find the manual on line to troubleshoot. Thank you
SOURCE: remote starter does not work but will unlock and lock doors.
I have a 2003 sierra and my remote starter would not work, it would lock and unlock only, checked out this site found the solution, tried it and in two seconds i solved the problem, Just press the lock button and the start button and viola it works again, thanks for all your help , GGGreat site glad i found it John
Posted on Jan 11, 2009
  • 9 Answers
depending on your alarm which it sounds like a viper model maybe? on my 02 you have to incorporate a factory alarm bypass module in order to be able to start the truck, they run about 100.00 bucks and have to be profssionally installed. The truck wont start because the computer isnt recieving the proper starting sequence due to the factory alarm
Posted on Jul 02, 2009
  • 3287 Answers
SOURCE: We have a 2005 GMC
Without knowing how old the battery(s) in the remote are, I would suggest that to be the first thing to replace. It is relatively easy and inexpensive to do - and could solve the problem.
You can attempt to pry the remote apart to access the battery(s) after removing the remote from the keyring, or bring it to a Batteries Plus store (or a hardware store) where an employee can replace it for you.
Beyond that, you'll probably have to return to the place of installation of the starter to resolve the issue. A phone call to the installer may be able to solve the problem over the phone instead of having to go there.
Posted on Sep 14, 2010
  • 587 Answers
SOURCE: Hello...my name is Shawn. I
http://www.retrevo.com/support/DEI-561R-manual/id/552dj492/t/2/
Posted on Oct 26, 2010
tunde007
  • 2382 Answers
SOURCE: hello,my remote central locking key
Hi, try replacing the battery in the key fob and if that does not solve the problem, reset the remote control, removing battery and refitting may reset, check user manual for the procedure for your car.
If that don't also solve it, contact your car dealer first before thinking of replacing the key fob.
Posted on Oct 29, 2010
Help me please I have a 94 Pontiac Grand Am SE. I jt bought it an put a new battery in it an put a new serpentine belt on it. I went to go to start it an nothing happens no clicking or anything everything...
Turn the key to the run position. Check the dash to see if the security light is flashing. If it is, leave the key in the on position till the light stops flashing. (this may take ten minutes) When the light stops flashing, turn the key to the off position. Then start the car. Make sure the head lights are turned off so that you do not kill the battery.
Dec 18, 2014 | 1994 Pontiac Grand Am
Pontiac torrrent won't start stabilitrack code
Bad starter, or battery cable connections going to starter
Jan 11, 2014 | Dodge Cars & Trucks
Electrical problems
Same thing is happening right now on a 2002 Monte Carlo. When the key is simply turned to ON, all of the lights on the dash starts blinking rapidly. When I attempt to turn the car over, there is no CLICK or anything from the engine - nada. Ignition turns and the dash goes dark, as if it wants to TRY to start - but nothing happens.
But, when I press the brake pedal (and the key is just sitting in the ON position), all of the blinking lights stops flashing and just stay lit. Therefore, I changed the brake switch, thinking it might make a huge difference. Didn't really help at all. When the key is turned, you can hear the fuel pump engage and everything seems to be ready to go. But, the car won't start (it will only start when it feels like it)...hit and miss, pretty much.
Does anyone know the TRUE solution to this issue? Does the ignition need to be replaced in order to get this car to crank over
May 05, 2012 | 2000 Chevrolet Monte Carlo
My daughter has a 2006 Pontiac Grand Am GT. She went to start the car and when she turned the key on nothing happens not even a click as if the starter is engaging. The head lights are bright and all of...
PARK SWITCH ------ STARTER RELAY-------- IGNITION FUSE
TRY SHIFTING IN NUTRAL TO START
SEE IF GROUND WIRE TO MOTOR AND BODY AS GOOD CONTACT
DOES POWER TO SIGNAL WIRE OF SELENOIDE ON STARTER COMES LIVE
WHEN TURNING KEY TO START
IS THE SECURITY LIGHT FLASHING IN DASH
Apr 22, 2011 | 2006 Pontiac Grand Am
Car will not start starter is good has spark can jump starter but will not run. if you turn key nothing happens 2003 Oldsmobile Alero
i have the same problem with 04 turn your key until the lights on the dash come on and see of the security light is flashing if so wait about 10 min for the security system to reset as soon as the light stops flashing turn the key off then your car should start right up
Jun 14, 2010 | 2003 Oldsmobile Alero
Mazda tribute 2005 want start
have battery load tested at locale auto parts. you may have a bad cell .if ok sounds like a selinoid problem
Aug 04, 2009 | 2006 Mazda Tribute
Nothing happens when I turn the key
Starter relay clicks but starter is not turns over. Check the starter connections and starter itself.
Good Luck
Feb 27, 2009 | 1994 Isuzu Trooper
GPS Logo
512 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
