Question about Altec Lansing AVS 500 Computer Speakers
Altec Lansing computer speakers model AVS500
Just wondering if you know whether the wiring input from the 18 volt adapter is is negative or positive? I purchased the speakers second hand and there is no indication on the side of the subwoofer whether it is a negative or positive. I've looked for the company site but unable to locate it.
Thanks,
Peter.
  • Tangoguy Nov 17, 2008
    I'm sure your solution would have been the correct one but since posting the question I have given up on the speakers and they now reside in a land fill.
    Thanks for your effort.
    Regards,
    Tangoguy.
18VDC 1000mA Center Positive.
Altec-Lansing
Part Number: AVS500-A6860
Model Number: 9701-00648-1UND
Posted on Nov 17, 2008
Look on the transformer that plugs in the AC outlet. If you don't have one to look at it says... Inside conductor is positive in the center of the connector. The outer conductor is negative.
Posted on Dec 21, 2008
Hello. I have the altec Lansing acs40speakers but no power supply. What voltage do these need?
Class 2 transformer
Model: 4815090r3ct
Input 120vAC
Output: 15 vDC, 900mA
Center is positive, outer is negative.
Dec 04, 2010 | Altec Lansing Multimedia Computer Speakers
Ac adapter for altec lansing model#acs40 voltage,current & polarity
Altec Lansing Model Number A 1664
Output 15 volts DC 800ma
center Positive +
Jul 29, 2010 | Altec Lansing Multimedia Computer Speakers
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
Altec avs500 speaker sound in 2 speaker only and not the rest
Try making sure the surround sounds knob is turned all the way to the right and that the switch on the subwoofer is on stereo and not gaming.
Mar 13, 2009 | Altec Lansing AVS 500 Computer Speakers
Power supply AVS500-A6860 fried
This one might work, but I'm not 100% sure on the connector:
http://cgi.ebay.com/AULT-041-0001-001-18VDC-1111MA-AC-ADAPTER_W0QQitemZ6741610952QQihZ002QQcategoryZ101265QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
Feb 16, 2009 | Altec Lansing AVS 500 Computer Speakers
What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Nov 20, 2008 | Altec Lansing AVS 300 Computer Speakers
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
AVS 500 subwoofer speaker
If you have a digital tester just select DC voltage then connect the positive leads of the digital tester to any of the wire coming out of the 18V adapter (WARNING do not connect to the wire connected to the main) and then the other lead of the digital tester which is the negative connected to the other wire of the 18V adaptor. If in the screen of the digital adapter reads a negative value, then it indicates that the other wire is the negative and the other is positive. Otherwise if the tester reads a positive value then your tester's leads have got the right connection.
P.S. please rate me.
Jun 10, 2008 | Altec Lansing AVS 500 Computer Speakers
AVS500 altec lansing speakers
Here is the link to the product manual. Hope this helps. :}
http://www.altecmm.com/downloads/LAT/AVS500B%20manual.pdf
There is a wiring diagram in it.
Nov 23, 2007 | Altec Lansing 621 Computer Speakers
Altec Lansing AVS 500 Computer Speakers Logo
792 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
