Question about Frymaster Dean 2424G Deep Fryer
Hi i have a frymaster model # mj145esd what size is it 50 lb or 90 lb thanks Bob rwilt@safetycheckonline.net
2 Suggested Answers
SOURCE: filter pump motor sparks when turned on. Trying to
Looks like the part number for the pump motor only is 826-1712.
Posted on Jun 20, 2011
NEED MANUAL FOR FRYMASTER MODEL MJH50BLCSC
Hi there.
Try seaching for manual at http://www.frymaster.com
Regards.
Jun 16, 2012 | Kitchen Appliances - Others
I wish to use my HP Photosmart C8180 to print heavy weight cardstock... is there a setting that I can select to do this?
Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
  • Plain paper, 20 to 24 lb (75 to 90 gsm)
  • Legal size paper, 20 to 24 lb (75 to 90 gsm)
  • Card stock, up to a maximum of 110 lb (200 gsm)
  • Envelopes, 20 to 24 lb (75 to 90 gsm)
  • Photo paper, 145 lb (236 gsm)
NOTE: Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
If you use card stock up to a maximum of 110lb then there should be no special mode to enter to print on this type of paper. Photo paper weighs in at 145 lb maximum which is heavier and can be printed on without selecting any special 'mode.'
Good luck on printing on heavy card stock.
Jan 21, 2011 | HP Photosmart C8180 InkJet Printer
Hi i was wanting to now if anyone knows the Torque Settings for the head of a 1992 Toyota Windom V6. Thank you.
Cylinder Head Torque Sequence
Tightening torque:
12 sided bolt
Step 1 ..... 34 Nm (25 ft lb)
Step 2 ..... Tighten an additional 90°
Step 3 ..... Tighten an additional 90°
Recessed head bolt ..... 18 Nm (13 ft lb)
Oct 21, 2010 | Toyota Passenger Cars & Trucks
Torque setings for cylinder head on t25 16d camper
It depends on the bolt type.
6pt bolt head (m11) - 1st 35 ft-lb, 2nd 50 then 3rd 65. warm engine and re-check at 65. After 1000 miles turn 90-degrees.
12pt (m12) 1st 29 lb-ft, 2nd 43, 3rd turn 90-degrees, 4th turn 90-degrees, warm engine and turn another 90-degrees. After 1000 miles turn ANOTHER 90-degrees.
Aug 30, 2009 | 1986 Volkswagen Wagon Camper
What is the heaviest weight paper I can feed through my Office Pro 7680?
Aug 09, 2009 | Office Equipment & Supplies
What should i torque the head bolts to on a 2001 ford 3.0litre engine?also the torque for the intake also!?
for a 3.0 2v....new head
    1. Install the bolts.
    2. Tighten the bolts in five stages in the sequence shown.
    • Stage 1: Tighten to 50 Nm (37 lb-ft).
    • Stage 2: Loosen the bolts one full turn.
    • Stage 3: Tighten to 30 Nm (22 lb-ft).
    • Stage 4: Rotate each bolt 90 degrees.
    • Stage 5: Rotate each bolt an additional 90 degrees.
  • intake bolts are:
    1. Install the intake manifold. Tighten the bolts in the sequence shown in two stages.
    2. Stage 1: Tighten to 15 Nm (11 lb-ft).
    • Stage 2: Tighten to 32 Nm (24 lb-ft).
    • work from the center out
  • Jul 07, 2009 | Ford Taurus Cars & Trucks
    Hp color LaserJet 3700 jams 70# uncoated letterhead stock
    Hi manitou344:
    Here is some info that might help you.
    Table 1-8. Tray 1 paper sizes1
    Media Dimensions Weight or thickness Capacity
    Minimum size paper 76 by 127 mm
    (3 by 5 in)
    60 to 163 g/m2
    (16 to 43 lb bond)
    100 sheets
    (75 g/m2; 20 lb bond)
    Maximum size paper 216 by 356 mm
    (8.5 by 14 in)
    60 to 163 g/m2
    (16 to 43 lb bond)
    100 sheets
    Minimum size glossy
    paper
    76 by 127 mm
    (3 by 5 in)
    75 to 120 g/m2
    (20 to 32 lb bond)
    Maximum stack
    height: 12 mm (0.47 in)
    Maximum size glossy
    paper
    216 by 356 mm
    (8.5 by 14 in)
    75 to 120 g/m2
    (20 to 32 lb bond)
    Maximum stack
    Minimum size
    transparencies2
    76 by 127 mm
    (3 by 5 in)
    0.12 to 0.13 mm thick
    (4.7 to 5 mils thick)
    50 sheets
    Maximum size
    transparencies2
    216 by 356 mm
    (8.5 by 14 in)
    50 sheets
    Minimum size
    envelopes
    76 by 127 mm
    (3 by 5 in)
    60 to 90 g/m2
    (16 to 24 lb bond)
    10 sheets
    Maximum size
    envelopes
    216 by 356 mm
    (8.5 by 14 in)
    60 to 90 g/m2
    (16 to 24 lb bond)
    10 sheets
    Minimum size label 76 by 127 mm
    (3 by 5 in)
    75 to 163 g/m2
    (20 to 43 lb bond)
    50 sheets
    Maximum size label 216 by 356 mm
    (8.5 by 14 in)
    75 to 163 g/m2
    (20 to 43 lb bond)
    50 sheets
    Minimum size
    cardstock
    76 by 127 mm
    (3 by 5 in)
    135 to 216 g/m2
    (43 to 43 lb bond)
    50 sheets
    Maximum size
    cardstock
    216 by 356 mm
    (8.5 by 14 in)
    135 to 216 g/m2
    (43 to 43 lb bond)
    50 sheets
    This printer can
    detect transparencies that were not designed for use with HP Color LaserJet printers.
    Jun 30, 2009 | HP Office Equipment & Supplies
    Oh and what do i
    TORQUE VALUE CHART
    7/16" dia. 50 to 60 lb-ft
    12mm dia. 70 to 80 lb-ft
    1/2" dia. 80 to 90 lb-ft
    5/8" dia. 110 to 125 lb-ft
    *Use this chart to get correct torque values for each size wheel stud. I hope this helps and don't forget to rate my answer.
    Feb 01, 2009 | 2002 Chevrolet Malibu
    Fryer
    Either Pitco SG line or any frymaster. These may be a tad more costly upfront but will save you down the road in repair costs and also parts will be available for a long time to come. I favor the pitco sg35cs myself this is a simple fryer very easy to repair and the parts costs are very resonable. As far as operating cost go in the fryer world they all are around the same.
    Oct 21, 2008 | Imperial IFS40 Deep Fryer
    Frymaster Dean 2424G Deep Fryer Logo
    287 people viewed this question
    Top Frymaster Dean Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    starztruck4u
    Dan Webster
    Dan Webster
    Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
