Question about GE 24 in. GSD6600G Built-In Dishwasher
GE GSD6610GOOB not cycling properly. Our dishwasher is about 6 years old and has been nothing but trouble the past year or so. We've already paid too much money repairing it the first time, (it simply stopped working - the control panel was totally dead) and don't want to pay anymore. Current problem - the machine starts up and fills with water and it sounds like it's running OK, then it will just stop, sometimes for a couple of minutes sometimes longer. Then it will start up again - and sounds like it's re-filling with water again, then stop again. This goes on for a while, then there are the usual cleaning sounds, and eventually the "clean" light lights up... except either the dishes are still dirty, or covered in soap, or a dried on film on everything. I've tried using different cycles, making sure it wasn't over-loaded, clearing out any gunk in the filter etc. etc. but nothing's worked.
  • 35 Answers
SOURCE: 1h (?) signal, and soap dispenser doesn't open
The part called a Wax Motor (about 2 inches) inside the door is responsible for opening your dispenser.Check it / replace it.
Posted on Dec 09, 2007
  • 54 Answers
SOURCE: DIshwasher Cycle TIme INcreases by 20 minutes over two years
Try cutting the breaker off for 5 min, This will reset the control. The issue is in order for a dishwasher to clean the dishes properly the water in the dishwasher needs to be at least 120 deg f. If its not the dishwasher keeps adding more time with the heater on to try to achieve this temp. The dishwasher only uses about 1 gallon of water per fill so if the water heater is a ways away or the temp is not hot enough, the water temp in the dishwasher will not reach 120.
Posted on Jul 04, 2008
  • 141 Answers
SOURCE: GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Posted on Sep 06, 2008
  • 276 Answers
SOURCE: dishwasher cycles but does not clean the dishes
if your dishwasher is cleaning poorly, check these: Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
  • 677 Answers
SOURCE: GE Profile Dishwasher (5 years old); Leaving residue on dishes
There is a new product out that actually filters the water going into your dishwasher. My dishes came out amazing after the first load. No more cloudy glasses. I was very impressed. Who knows whats in the water cleaning your dishes so i thought this filter was great. It is very affordable and you can get it at Hope this helps some people.
Posted on Jan 06, 2009
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Not cleaning dishes
For starters run the dishwasher through its entire cycle empty and add only one cup of vinegar. This will clean and disinfect. Next run the dishwasher through a second full cycle with nothing but water. This may be all you need to do to get your dishwasher back up and running.
Apr 30, 2009 | Dishwashers
Rotating arms getting clogged very frequently
I do not have a huge amount of information about the GE Profile PWD7880 handy, so I don't know if it has a chopper blade/food disposer at the bottom of your Dishwasher, but when a dishwasher gets the holes of the spray arm, the most common cause is the chopper blade is jammed/blocked. Then the food debris never gets sliced and diced at the end of the of each wash cycle.
Opening up the filter under the spray arm, removing as much of the lower assembly and inspecting every where in the sump area, especially the drain pump area would be a great beginning.
Good Luck! Just ask if you have more questions.
Apr 04, 2009 | GE 24 in. Profile PDW7800 Built-in...
2 year old GE Nautilus dishwasher
Check the pump, make sure it is working properly and pumping water out. If it is then check the drain hose and make sure it is not plugged.
Feb 11, 2009 | GE Nautilus 24" Built-in Dishwasher
GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
My washer is 2 years old and this is 1/2 the cost I paid for it new. My review of this product after 35 years of technical experience; GE products (Hotpoint)aren't worth buying any longer.
The problem is the Motor. There is an electronic PC Board attached to the top of the motor and under the drip protector, which protects the PC Board. On this board, there is a green flashing light which displays trouble codes by flashing. Unplug the washer, remove the 3 screws from behind the control panel. Slowly pull the control panel toward you and slide it to the right to release. Inside the washer, there is a diagram with the trouble codes printed in the lower right hand corner. Everything else is self explained. Flashes indicate the problem and the solution is all written. Since I have the same problem and a technician, this is a defective product GE has discontinued and re-manufactured. After phoning GE the motor # Normal 0 WH20X10051 cost $252.25 to ship to my location.
Jan 09, 2009 | Washing Machines
GE profile dishwasher does not drain out aat end of cycle
I just fixed the very same problem by replacing the piston and nut (part # WD24X10018).
Jan 07, 2009 | GE Dishwashers
Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
Possible loose seal
Dear friend,
ngfam at you service! happy to assist!
Call service and have them change the door sensor!
This is an electronic part!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Aug 13, 2008 | GE 24 in. Profile PDW7800 Built-in...
Oct 09, 2007 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. GSD6600G Built-In Dishwasher Logo
63 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
