Question about Eureka 5841 Upright Vacuum
How do I replace the Eureka Boss 5841 motor and what is the cost for that replacement motor?
reddevil6
  • 1673 Answers
SOURCE: Eureka the boss vacuum cleaner brush won't turn
Take the top cover off, remove the torx screws on each side of the motor housing, remove the screw on the back holding the hose, then you just have to compare the 2 before putting on the new one. Can't tell for sure without a model number to get you a picture. What isn't on the new base, take off the old base and put it on the new one.
Posted on Mar 02, 2008
SOURCE: eureka whirlwinde litespeed vacuum - model 5841
very simple under all three screws in the front (two on sides and one in back) once open--you can take off that panel...take brush out...take old belt out...put new belt on..around brush..place both inside...and make sure belt is around that little pole thing towards the back close panel, replace screws
Posted on Jul 24, 2008
  • 21 Answers
SOURCE: Battery Pack for the Eureka Boss Model 93B
tHE 96 F IS ALMOST THE EXACT SAME AS THE MODEL YOU HAVE. THEY HAVE THE SAME POWER TO THEM THE BATTERIES WERE JUST DIFFERENT
Posted on Jul 19, 2009
  • 21 Answers
SOURCE: My Eureka Boss vacuum belt keeps breaking
How long hace you had your vacuum? THe belts on this vacuum are actually supposed to last a really long time. If the belts brake faster when your using the hose that impies your clutch which tightens and loosens your belt to keep the brush from spinning while the vacuum is upright couild be malfuntioning. If you post your serial number i can tell you if your still under manufacturers warranty.
Posted on Jul 23, 2009
SOURCE: vaccum wont work
There is also a reset button on the side at the bottom. Good luck.
Posted on Nov 03, 2009
Eureka boss sucked up water and won't work
The water probably got into the motor causing it to "burn" out. The motor will need to be replaced, but by the time you include labor cost it may be cheaper just to replace the vacuum.
Dec 24, 2013 | Electrolux Eureka Boss SmartVac Vacuum...
The belt on my used Eureka Boss 5857 upright slips off the end of the motor shaft every time the vacuum is used. When I turn the brush roll slowly by hand, the belt walks toward the end of the shaft. It...
The brush roller could be worn and in need of replacement. Some Eureka uprights have a wire guide that prevents the belt from slipping off the motor shaft.
Apr 02, 2011 | Eureka 5856BVZ Boss Bagless Upright...
Eureka 5841 Upright Vacuum Handle will not latch to stay upright
The pedal is probably broken or stuck. You should be able to see where it catches when you stand it upright and determine why it won't catch.
Jul 21, 2010 | Eureka 5841 Upright Vacuum
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Owner's Guide (3,666K download)
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
How to replace belt
Below I have listed a link to the owners manual which has instructions on how to change your belt and a link for the belt you need. Hope it helps!
Owner's Guide
Replacement belt for Eureka 5841
Oct 30, 2009 | Eureka 5841 Upright Vacuum
My wife's Eureka 5855 Boss Bagless Wide Track stopped running
its probably something in the motor. you may have to replace the motor which could cost around $50.
Apr 15, 2009 | Eureka 5849A Boss Bagless Upright Cyclonic...
Eureka 5841 upright vacuum cleaner quits running, it takes a very long time before it will start again
The motor is running hot and causing a emergency shutdown. It is either clogged somewere or the motor is bad check for cloggs first then if none are present you will have to replace the motor. Depending on the original price of the machine if the motor is bad you may be better off buying a new machine.
Apr 13, 2009 | Eureka 5841 Upright Vacuum
How do i replace the fan blade assembly which are broken in my ureka model the boss thank you lorne
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=540001
Generic problem for all Vacuums
Posted by lmurray1 on Apr 23, 2008
How do i replace the fan blade assembly which are broken in my eureka model the boss
thank you
lorne
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are 2 different models of the boss by Eureka – there is a standard old style upright that the belt that the belt would unscrew from the bottom of the motor and you would have to remove the top of the vacuum cover to remove the main motor and gasket assm, and then the fan has a reverse thread on the plastic fan and you would unscrew the fan after removing the belt pulley. Then you would screw on the new fan, belt pulley, replace the gasket and re-install the motor. If you have a new style with a side mount motor you would remove the top cover, the motor would be in there sideways, un-screw the motor, remove the silver tape around the fan housing and un-screw the fan housing – same as above un-screw the fan from the motor, there is a nut on the end of the fan holding that on – (remember, the fan has a reverse thread) re-install the fan. Then the fan housing, replace the silver tape, and then screw down the motor and replace the top cover, then you can test. As always free to contact your local vacuum dealer in your area in the yellow pages or contact your Eureka factory manufacturer listed below:
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Vacuums
Eureka 5841 Upright Vacuum Logo
63 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
