Question about Bugaboo Cameleon Stroller
My Bugaboo chameleon has started to veer quite badly when on slightly uneven pavements (ie. sloping slightly from one side to the other). I am permanently having to correct it, which is quite hard work and I end up with sore wrists! Any ideas? Thanks a lot
SOURCE: brake(?) rubbing on left big wheel when not on level surface or turning
The same thing happened to mine. I had a good look at what was going on and decided that the length of brake chord is ever so slightly too short. Even with the brake cable adjuster as far "down" as it can go, the chord brings the brake shoe up too close to the wheel making the "raspberry noise" on the left. I got my brand new bugaboo suspiciously cheap and am now wondering whether perhaps it was a factory second because of the short chord.
Anyway, after a bit of tinkering the problem has been almost eradicated, it now only makes the rude noise on the tightest of turns.
1) First, ensure the brake cable adjuster is as far down as possible by rotating it clockwise until you can rotate no further. It can be a bit fiddly so try taking the right big wheel off to get better access to the adjuster.
If the adjuster was not at the bottom before then put the wheel back on and give it another go - it might now work!
2) if not, turn the chassis upside down and identify the thinner cross-bar, just above the "big wheel" axle. You should be able to see 2 screws, one at either end of the bar.
Unscrew the screw at the opposite end of the bar to the brake cable. Now, GENTLY pull the brake at the same end( the green nobbly bit)upwards, towards you whilst re-tightening the screw you've just removed. Only release the little bit of tension on the brakes once the screw is fully tightened.
This step might seem a bit pointless, as it appears that you unscrew a screw, then do it straight back up. Fair point but that tiny bit of flex in the brake/crossbar assembly made all the difference to ours!
I do hope this helps - I really think there is a bit of a design fault here as ideally the adjuster should be set in the middle of the range so that adjustments can be made either side of the neutral. Mine is right on the lower limit and hence has no further room for adjustment. Unless of course it is, as I say, a factory second!! Sorry if I've gone all technical.
Posted on Apr 03, 2008
  • 274 Answers
SOURCE: bugaboo chameleon 2 wheel position?
ASK FRED @ WWW.BUGGYPITSTOP.CO.UK
Posted on Jan 06, 2010
  • 274 Answers
SOURCE: Bugaboo chameleon stroller won't collapse
hi there go to www.buggypitsop.co.uk they do repairs to bougaboo and other pushchairs.
Posted on Jan 11, 2010
  • 274 Answers
SOURCE: bugaboo gecko pram unit slopes forwards when on chassis
get in touch with www.buggypitstop.co.uk they do repairs to bugaboos
Posted on Apr 15, 2010
My Bugaboo Chameleon veers to the right- the wheels are intact but something seems to be off. It makes it impossible to push with one hand. Any idea what could be worng?
First check that both front wheels are set to the same spring tension. Next check that all four wheels spin freely and the front two can swivel around 360. If all OK push up and down on the handle bar, the inch or so of movement is usual for a Bugaboo but both sides of the handle should stop at the same position. If not then you have a problem with the locking pins in the handle hubs. Check here for more info. www.fixya.com/support/r7805199-fix_bugaboo_handle_lock
If you find this helpful please tick the box to say so. If not please let me know. Every time I answer a question it actually lowers my overall rating unless voted on.
Aug 30, 2011 | Bugaboo Cameleon Stroller
Bugaboo chameleon frame not locking into place
www.buggypitstop.co.uk are the only company that repair bugaboo handles.Highly recommended they will fix it at a faction of the price of a replacement handle
Feb 24, 2010 | Bugaboo Cameleon Jogger
Dec 19, 2009 | Bugaboo Cameleon Stroller
Chameleon: brake not secure and extendable handle lock jammed
This has been solved elsewhere on this site - do a search, but spell Cameleon without the H in it and you'll find it
Aug 31, 2009 | Bugaboo Cameleon Jogger
How do i remove front wheels on bugaboo chameleon? thanks
The part of the front wheels that pokes out above the connection point has two slightly flared pieces. Squeeze them together and pull the wheel back through the connection point.
Sep 07, 2008 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Stroller Logo
204 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
