Question about Mitsubishi WD-52631 52" Projection HDTV
Can I replace the DLP lamp myself or do I really need a repair technician to do this?
  • Mitsubishi Master
  • 8,457 Answers
U can replaced the DLP tv projection Lamp ur self.Try website like YouTube.com.Type in Mitsubishi DLP tv projection lamp replacement.There will be a tutoring video by somebody,replacing the DLP tv projection lamp.Tries websites like Ebay.com,Partstore.com to buy a new DLP tv projection lamp.
Posted on Oct 15, 2010
My Mitsubishi tv WD 73734 won't show a picture you can hear sound and it powers on and off lamp light red and timer lighter blinking
No TVs will behave that way due to a timer. TVs only will display a nag screen telling you to reset the timer. If your lamp is more than 2 years old, it is suspect of failure. Be sure you buy a lamp with an Osram brand or Philips brand bulb inside. Any compatible(knockoff)lamps will not perform as they should. Mitsubishi DLP TV Bulbs
These folks sell original Osram bulbs in their lamps and they have a 6 month warranty. I use them myself for repairs and really have had great experiences with them.
Sep 09, 2015 | Mitsubishi WD-73734 73" Television
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
How much does it cost to repair a Panasonic 57''
Hi,well price depends on what part you are fixing.Technicians do charge crazy prices.For instance if your tv was a dlp and you needed to replace the lamp the part will cost around $100.00 a technician will charge you $250.I recommend NESDA technician they are honest and dont charge you as much as others do.
Nov 18, 2009 | Televison & Video
Loud whirring noise in my Samsung dlp rear projection tv. HL-M507wx/xxa. Is this the color wheel or cooling fan? can I replace myself? I changed the lamp and that was pretty easy.
fan is easy to replace, color wheel will require a technician.you can remove lower back cover and see the fan but i'm guessing it's the color wheel.
Nov 04, 2009 | Televison & Video
Blue gost on right side of screen
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast board with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
this are the instructions to do it yoursely manually.
but its worth getting new tv.
Apr 01, 2009 | Televison & Video
Samsung 50" DLP Lamp died, new lamp will not light`
Bad news.  Mine did the same thing.  Mine is the 61", but the internals are basically the same.  I replaced the lamp and the problem was fixed.  Then after a couple days, it died again.  I replaced the ballast, to no avail.  Took it to the certified repair center and they said I needed a new DLP Light Engine.  They wanted $1250 to fix it, but I was able to order one online from partstore.com for $700 and fixed it myself.  No problems since.
Your certified repair center will charge a minimal fee to diagnose and then you can fix it yourself if you choose.
The easist fixes for the lamp problems are A) replacing the bulb and B) replacing the ballast.  Anything else, you'll want a certified tech to diagnose the problem.
Jan 17, 2009 | Samsung HLN5065W 50" Rear Projection...
50? Samsung DLP TV Model #HLR-5067W
Did you use an original replacement lamp or an aftermarket replacement? From the price you give, it sounds like an aftermarket lamp, which are notoriously buggy and the problem may be with the lamp. If not, the lamp driver is your next likely culprit. It is also called a lamp power supply or lamp ballast.
Oct 19, 2008 | Samsung DLP HL-P5663W 56" TV
Bought 3 MP3300 projectors for presentation projects
OK first thing if you have broken the disk on a DLP projector, you can not repair with out specialist equipment to set it up, as for your other ones it sounds like your lamps are faulty, you must not use lamps over the rated hrs or you will damage the projector, if you want more help just ask me but unfortunatly in am in the UK so cant vist.
Marc Engineer
Oct 19, 2008 | Dell 3300MP Multimedia Projector
DLP TV Samsung HLP4674w No Picture
If you hear a ticking and or buzzing sound as it is trying to start up then most likely the replacement lamp is bad. Take it out and reseat it one more time to see what happens. The noise you hear is the ballast attempting to fire the lamp up.
Nov 30, 2007 | Samsung HLP4674W 46" Rear Projection HDTV
Mitsubishi WD-52631 52" Projection HDTV Logo
423 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
