Question about Necchi 4595 Mechanical Sewing Machine
I broke a needle and when I replaced it my nice stitching disappeared. Thread is very loose in the top of the machine. I misplaced the manual in a move, so I may not be inserting needle correctly.(?) I need quick help on this...also a way to replace the manual.
  • Necchi Master
  • 7,365 Answers
The flat side of the needle goes to the back of the machine
I also have the same sewing machine, if you will send me your email address thru a comment & I will copy pages of the operation manaul & send them to you
Posted on Oct 15, 2010
Bobbin stitch is loose. can be pulled out
When the bottom stitches are loose it usually means the machine isn't threaded correctly. Un thread the machine and take the bobbin out. Rethread the top making sure the thread is in the tension slots securely. Replace the bobbin making sure it is inserted correctly. You might also need to replace the needle.
Jul 02, 2017 | Sewing Machines
How do I fix my loose bottom tension?
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread the machine from the beginning. Verify the path is correct. The standard tension setting is the midway point although you will most likely need to tweak this for your particular machine.
If you are still having problems, you may need to readjust the bobbin tension.
Understanding Thread Tension Threads
Feb 21, 2017 | Sewing Machines
I have juki 1541industrial machine . It started sewing upside down . Instead of nice stiching on top show side it on bottom. Any ideas
This is caused by the tension between the bobbin and needle threads being out of balance. If the knots between the stitches are on the bottom side, then you need to tighten your needle thread tension a little at a time until the knot is in middle of fabric. The reverse of this is if the knots are on the top, then either your bobbin tension is too loose or your needle thread tension is too tight. If this occurs, then loosen your needle thread a little at a time to see if knot goes down in middle of fabric. If it does not, then you need to increase the tension on your bobbin thread. This done by taking bobbin case out and tighten the small screw located in the middle of the spring on the side of the case. You only need a slight, steady pull on the bobbin thread - the more you put on the bobbin, the more you are going to have to put on the needle thread.
Feb 13, 2015 | Juki Sewing Machines
Baby lock repair manual for oiling also have problem with top tension or bobbin tension not sewing right when I pick the sewing pattern and it's all over and thread loose and miss stitch. Is there a manual...
First thing, install a brand new needle. Old, damaged needles will skip stitches. Needles should be changed at least every 8 hrs of use.. You don't say which thread is loose. If top thread, remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from beginning. Set top tension to midway point and re-test the machine.
If top thread is still loose, increase the tension. Tension is correct when both threads meet in the middle of the fabric. The two threads play tug-of-war against each other. When both tensions are even, the stitches will be uniform.
Free manuals are difficult to find for Baby Lock and service manuals are usually not available to the public. If your machine is computerized, it probably should not be oiled except by a qualified technician. If the machine is mechanical, most times a drop or two of "good quality" sewing machine oil applied every place where metal rubs metal parts will help the machine.
Nov 25, 2017 | Sewing Machines
How do you start embroidering a design where the thread breaks on a Bernina Artista 180 sewing/embroidery machine?
Most machines have a stitch counter, stitch forward and step back features. Check your manual and embroidery machine's screens for this.
IN case you have misplaced your manual I found this one for you. It's big so allow time to download.
http://www.itsastitchonline.com/mastery_on_the_web/Mastery_170_180_1-10-02.pdf
Sep 10, 2012 | Bernina Artista 180
Which needle do I take out to do a rolled needle
left one, rolled hem is usually a narrow seam so you remove the left needle, change the needle plate or flick a switch that changes the position of the thread finger under the foot and tighten up the looper tensions. You want the top looper thread to go around to underneath and the bottom looper thread to disappear against the needle stitching. You also need to close up the stitching density, by decreasing the stitch length.
Mar 02, 2011 | Baby Lock Eclipse Serger
Top thread won't create a stitch
Hi! Check that you installed the new needle correctly. There is a flat side on the needle shank and that has to be facing the rear (away from you) on this machine in order for the top thread to catch the bobbin thread and make a stitch.
Let me know if this works, ok?
Robbie
May 11, 2010 | Kenmore Sewing Machines
Stitches are looping on the underneath and missing some stitches
Refer to the manual for cleaning.
Replace the needle with the size recommended for the type of fabric being sewn. The flat side of the needle is usually facing the back of the machine - check manual to be sure.
Always thread any sewing machine with the presser foot up. This opens the tension control so the thread can properly enter this device.
When a sewing machine is threaded with the foot down, the tension control closes and the thread cannot enter as it should
You then get loose stitches because the top thread and bobbin thread cannot make a proper stitch and the tension of the bobbin thread is pulling the top thread to the underside of the fabric.
Mar 07, 2010 | Janome Sewing Machines
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
Jun 27, 2008 | Juki TL-98Q
Necchi 4595 Mechanical Sewing Machine Logo
67 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
