Question about HP LaserJet P3005 Printer
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
  • Seeker5211
    Seeker5211 Oct 15, 2010
    Measure the distance between the lines. It will tell what is causing the lines.
  • 48 Answers
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Posted on Oct 15, 2010
  • whandrow885 Feb 10, 2011
    Replacing the fuser only makes the lines worse, transfer roller has been replaced, and the fuser drive gears, new toner only makes worse. Have seen this issue on a number of these printers lately but have not found a fix. Power supply maybe?
  • Seeker5211
    Seeker5211 Feb 10, 2011
    Run the 1/2 print test
    Feed paper from the manual feed tray. As the paper gets half way in open the top cover, pull out the toner and look down at the paper.
    If you see horizontal lines the toner cartridge is bad. If the page is clean( no lines) its got to be the fuser or else the printer is abnormally dirty inside.
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
When I print 1 copy from my laptop, it will not stop printing many copies and I tried to copy a photo and there are horizontal lines on the copy. Jacques
The numbers of copies your laptop print out is set in your printer software.
You did probably forget to change the numbers to 1 (one copy).
If you use normal print paper for photos, it will almost always make horizontal lines.
Use photo print paper instead, then it won't happen.
It could also be that your print cartridges need a nozzle cleaning.
Normally your printer software has a mode to this.
Hope this will help you
Regards
Aug 29, 2011 | Kodak Cameras
Hp 2500l prints a dark line horizontal down each page. Can we clean drum at home?
A dark line on the hp 2500 series can come from the drum You can't clean it at home), it can come from a toner cartridge, from the fuser unit and from the optics.
Step one - check if the line in all colors, run copy quality check through Menu and diagnostics, if the line is only on one color your problem is the toner cartridge.
Step two - if the line is on all colors, take the drum unit out and look at the drum, if you see the line on the drum you need to replace the drum unit.
Step three - stop a print in during the printing process by turning the printer off, take out the drum and look at the printed paper under the drum, if the printed page is clear of line your problem is in the fuser.
Good luck.
Dec 14, 2010 | HP Color LaserJet 2500L Laser Printer, up...
Black lines in pictures printed from Artisan 800
I have the same issue, It seems 1 line of pixels is overlapping with the next set of pixels and makes a dark line horizontally.
Apr 23, 2010 | Epson Artisan 800 All-In-One InkJet...
Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Oct 01, 2009 | Lexmark Z705 Inkjet Printer
HP 5610xi all in one printer, Lines in the copy
Are these dark lines or 'white' lines where ink isn't being applied to the paper where it should? And are they horizontal or vertical lines on the page?
If vertical lines on the page, follow these instructions:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
May 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Dark lines on edges of copies
make a copy when you here the paper getting picked up count 2 seconds and open front cover or side stopping the process open the copier and see if the dark line is on your drum or transfer is the problem
Nov 23, 2008 | Sharp AL-1642CS Copier
Xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
I
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
print.
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
color.
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
3041-42
Leading Edge
hope that this will help you.
Sep 18, 2008 | Xerox Phaser 7700 Laser Printer
Copies print with horizontal lines
thin lines? spaced about 1.5 inches apart could be toner left on the drum, take the cartridge out turn it over and retract the shutter, manually turn the drum using your thumbs on the edges of the drum, do you see thin lines on the drum? sometimes something sticky gets on the drum attracting toner and then it transfers to the paper during the copy process
Dec 20, 2007 | Office Equipment & Supplies
HP LaserJet P3005 Printer Logo
859 people viewed this question
Seeker5211
Seeker5211
