Question about HP Officejet Pro L7680 All-In-One Printer
I have an HP Officejet 7500. This morning the printer was offline and could not restore connection. In the past I would delete the printer and re ADD the printer. However this time when I tried to Add the printer (network printer) the computer was not even recognixing the HP 7500 as even being in the network. What do I do?
  • daschon Oct 16, 2010
    Great job Guys! Looking forward to more business.
  • HP Master
  • 19,396 Answers
Hi.
If connection is USB:
First restart computer and printer and have a look at the USB cable (if printer is connected through USB).
While restarting the computer also disconnect printer and computer power cord for about ten minutes, this will drain power completely, and can fix problems caused by electrostatic charges that can affect USB.
  • Turn off computer.
  • Turn off printer.
  • Disconnect computer power cord.
  • Disconnect printer power cord.
  • Disconnect USB cable.
  • Restart computer.
  • Check on computer if there are docs in printer cue and delete them.
  • Restart printer.
  • Connect USB cable.
If that does not work, then you need to reinstall the printer software. In that case you can download updated software here:Software Downloads HP Officejet Pro L7680
To reinstall printer:
  • Remove printer from installed printers.
  • Choose to remove all driver files if asked.
  • Reinstall printer software.
  • Connect USB cable when prompted by setup wizard.
If instead of USB the printer is connected trhough network cable or wireless network, then check that the computer has connectivity. In that case the steps are:
  • Disable firewall
  • Restart router, printer and PC.
  • Check network connectivity on computer.
  • Reinstall network printer.
Posted on Oct 15, 2010
  • Ginko
    Ginko Oct 16, 2010
    Hi.
    Thanks for the feedback.
    Have a good day.
    Ginko.
Hp officejet 7500 e910 printer offline
Hi Ida Kingsberry,
I would be happy to help you with your HP Officejet 7500. Please refer to the following document to troubleshoot a printer offline message:
http://support.hp.com/us-en/document/c02241610
Please let me know if this resolves the issue, or if you require further assistance. Thanks.
I work on behalf of HP.
Jul 21, 2015 | HP Office Equipment & Supplies
My printer says it is offline HP officejet Pro 8630
Re-install the printer
A number of things such as updates, restarting the router etc etc will have caused it to do this.
3 ways of doing it:
1. Use the disk.
2. HP Officejet Pro 8630 All in One Printer Software and Drivers click software and drivers, follow the steps
3. Go to start > devices and printers > add printer > choose local if connecting via USB, choose networked printer if wireless, click next and follow the steps.
Jun 15, 2014 | HP Pavilion dv5000t Notebook
Undo delete
my printer xantefm4 are installed with xp but it is apparead" no usb"
Feb 16, 2014 | HP Office Equipment & Supplies
My HP Officejet 6210 All-in-One printer goes offline whenever I don't use it for about 15-20 minutes, and when I put it back online, nothing happens. Looking at the printer from the control panel, I see...
HP Printers have common behavior of going into sleep mode if not used for a while. If this happens every-time the printer goes to sleep mode and you find printing issue, try this simple step below
Disconnect the power cable from back of printer
While holding the # and 3 button, connect the power cord to printer.
*Note this is partial reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I have dv7 1023cl notebook and connected HP officejet all in one pinter that worked fine for the past one month, suddenly it stopped printing with no defined error message. I have checked all the...
What I do in a case like this is do a system restore back to the time it worked. There is a chance that something in the registry got messed up and a restore should get it working again.
Sep 18, 2010 | HP Pavilion dv7-1132nr Notebook PC
My HP OfficeJet 7410 is offline and I can't get it back online -- I have checked all connections. This happened after the last Vista update. Also, when it did print, the duplexing didn't work. Help!!!
Since this happened AFTER a Vista upgrade, I suggest that you look at the printer in the hardware are of Vista.
1. First remove the printer from the group of devices.
2. Reboot with the printer attached.l
If the printer does not automatically reinstall, then manually add it by using the Add Printer selection.
If you have two printers in the list delete them both and then reboot.
Dec 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP OFFICEJET PRO 8500 GOES OFFLINE
on hp.com they have driver updates try just updating the driver
Jun 27, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet 4315 All-in-One went offline
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | HP Officejet 4315 All-in-One Printer
My Hp Officejet 6300 All-In-One printer will not copy
printer is offline yet cables are connected and printer was working a day or so ago!
Jan 19, 2009 | HP OfficeJet 6310 All-in-One Printer...
Printer keeps becoming disabled
Usually, it happened when the usb cable is unplug, what you can do if the printer says OFFLINE.
1. Right click the printer ICON, and
2. Choose, USE PRINTER ONLINE.
Actually, you dont need to delete or uninstall the printer driver because it will just take some time. setting the printer to ONLINE by folowing the steps would save much of your time.
Please, let me know if the steps i gave you would help you so much.
thank you so much.
adonscott
Jul 21, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
1,042 people viewed this question
Seeker5211
Seeker5211
