Question about Bunn NHB Coffee Maker
Hi i lost my cleaning rod i made one with 2 wireties and it brock one is in the tub and takes forever to make coffie
Dryer gets hot but takes along time to dry
Make sure the lint filter is clean. If it is make sure the hoses leading from the dryer to the outside are not clogged. It sounds like it is not getting prober airflow through the tub.
Jun 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Drain stopper won't engage to keep water in tub for bath
Hi, looking at this straight on, you will see 2 screws going through the lever plug section. What it looks like on the inside, is a long brass rod connected to another brass rod with a adjustable section on it and a brass looking piston at the end. If you remove the 2 screws, grab hold of the lever and chrome plate and pull straight out and up to remove the assembly.No worry, nothing will fall in as it is all one piece. You can try cleaning the lever section up and add some wd-40 to it and this may help some. It sounds to me like the lever ball joint is worn out, so it is best replaced. Home Depot has them for under $20.00. Take the old one with you and if need be you can adjust the new one to the same length as the old one. It will keep hanging up on you believe me. Good Luck,
Shastalaker7
Nov 17, 2009 | American Standard Plumbing
Large banging in tub during spin cycle.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 08, 2009 | Kenmore Washing Machines
Washer spin off balance
Apr 04, 2009 | Kenmore Washing Machines
I overloaded my washing machine!!
Hi Tracy, welcome to Fix ya.
I believe know exactly what happened here- one or more of your tub support rods has broken and that caused the tub to drop down. Those are actually pretty easy to change yourself! Lift the lid, look for two plastic caps, one on each side, that cover the screws the secure the washer top to the cabinet. Pop the caps off, take out the screws. Now the whole top can be opened up (it's on a hinge of sorts) and now you can see the main basket/tub assembly. The rods fit in a recess on the tub at the bottom and on the top of the rods, the triangular plastic sits in each corner of the machine. There are no tools needed, these rods come off very easily.
You can get a set here: (They are sold in sets of 4 and should be replaced as a set)
http://www.fisherpaykelparts.net/ecart/item.php?item_id=218&category_id=46
I hope this info is useful to you.
Feb 26, 2009 | Fisher and Paykel GWL11 Top Load Washer
Poor DS
u gave it to them
Jan 22, 2009 | Nintendo DS Lite Console
My coffie maker leaks water when starting to make coffie
i have lost the user manual for the m200, could you please advise where i could get one.
thank you
Nov 22, 2008 | Coffee Makers & Espresso Machines
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Lost manual need cleaning instructions
You can download the operating manual for your machine in pdf format right to your computer from www.bunn.com By the way, I wouldn't personally put vinigar in any Bunn machine, as it takes forever to run enough water through them to get rid of the vinigar taste.
Jul 15, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn NHB Coffee Maker Logo
91 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
