Question about Logitech diNovo Edge 9676850403 Keyboard
Dinovo edge keyboard
My dinovo edge will not take a charge, when I put it on the charging base the battery light flashes red and it does not take a charge.
  • 3 more comments
  • dthoward11 Aug 08, 2008
    I am having the same problem with the keyboard not charging. I put it on the cradle and the power light go red and green but does not charge.
    Need a solution.
    Thanks.
  • jamiepedder Sep 11, 2008
    Mine used to work, but recently when put in the charging cradle, the charge indicator goes green for a second, then starts flashing red. Have tried flicking the power switch, cleaning contacts etc with no joy. Going to have to bin it if I dont find a solution soon because if its not charging it will run out of power soon. Does work OK right now, both in and out of the base.
  • Anonymous Nov 25, 2008
    purchased 11/24/08. same bad behavior.
  • Anonymous Feb 16, 2009
    same here
  • docnyc Feb 20, 2009
    When I dock the keybaord, intially I have a flashing green battery light, but then it stops flashing, stays green but does not charge.
Try flicking the orange power switch on the side of the keyboard while the keyboard is sitting on the charger
Posted on Sep 07, 2008
Disconnect the keyboard from your Mac's Bluetooth configuration (One way: System Preferences > Bluetooth; select the keyboard and use the "-" minus sign to remove it). Now place it in the charger. The red blinking should stop and normal green-blink charging should take place. You should only have to do this once. I love this keyboard.
Posted on May 25, 2010
  • 3 Answers
Phone Logitech - it has a 3 year warrenty, they should replace it..........
Posted on Aug 19, 2010
The solution is don't by this keyboard, they all end up like this it's junk, due to a poor battery.
Posted on Nov 07, 2008
3 Suggested Answers
AldRezaine
  • 995 Answers
SOURCE: dinovo edge wireless keyboard base charger NOT SOLD SEPERATELY
You can buy the charger at any computer stores in your place. Just ask for it and if the store you enter does not have that item, they can order that kind of charger from there supplier.
Posted on Nov 05, 2009
SOURCE: Logitech DInovo Edge: When I charge the keyboard
It looks to me like Logitech changed the design a bit. I found no such "CAP", however the problem did in fact lie in the same spot under the sleep button. I found a flat cable that had 6 jumper wires running through it to be the culprit. The cable was made too big, so they bent it to make it fit thus damaging it. I'm going to have to replace it, but just from playing with it a little I got my keyboard to turn on advertising a full charge and when I set it on the base I get a green light off happiness.
Posted on Jul 09, 2010
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Logitech DInovo edge spacebar not working
try to remove dust in your keyboard by using paint brush or compressed air.
Nov 05, 2013 | Logitech diNovo Edge 9676850403 Keyboard
Spilled water on keyboard diNovo Edge now it wont charge
First, take the chargerstation and put in the keyboard. Does the keyboard work if its in the charger? Make sure its well connected.
If it workes you only fried the battery. Buy new battery at ebay and replace it. Just drag off the orange plastic in behind, just use sharp screwdriver and unscrew all screws. Dont forget unscrew the screws under the warrantyseal by the chargerpoints. Then open up and replace battery, and yea it should work fine again.
Jun 03, 2013 | Logitech diNovo Edge 9676850403 Keyboard
It wont load properly and when i take it out of the charging station it starts to beep and flash frequently
Possible that the battery is not charging well or the cell is weak and worn out.
Remove to check and replace.
Sep 12, 2010 | Logitech diNovo Edge 9676850403 Keyboard
Logitech DInovo Edge: When I charge the keyboard in the station, Setpoint tells me that an error has occurred while charging. The battery lights on my keyboard are flashing green and red. is my charging...
Jun 07, 2010 | Logitech diNovo Edge 9676850403 Keyboard
My Logitech Dinovo Edge is not recharging. When I put it in the charger the battery charging indicator light flashes red instead of green.
Were you having problems with short battery life before this happened? Most of the time if the battery is not recharging it needs to be replaced. Have never seen the red flashing light before though. It may mean that the battery has shorted out.
Jul 24, 2009 | Computers & Internet
Logitech dinovo edge will not power on
What are you trying to ask, are you saying that this doesnt happen on your dinovo, is the charging dock plugged into a working outlet. Check that, if it doesnt work at all, contact logitech for a replacement.
Mar 18, 2009 | Logitech diNovo Edge 9676850403 Keyboard
Hi i cant find logitech dinovo edge charging base
I just posted a logitech dinovo edge charging base on ebay if you are interested. LINK
Mar 09, 2009 | Logitech diNovo Edge 9676850403 Keyboard
New battery pack search
The screws are on the back under the orange cardboard cover.
The battery is a Li-ion 930mAh 3.7V
190304-2004 R-IG7
L/N: K44B
The brand on the battery is logitech.
May 13, 2008 | Logitech diNovo Edge 9676850403 Keyboard
Battery problem,...
I had this problem with mine so lets start by saying there are solutions!!
Solution 1:
Logitech state the battery cannot be replaced. It CAN. You can purchase the exact battery from ebay. Its a simple case of taking the orange backing off, removing all the screws (not forgetting the one hidden under the bluetooth address sticker) and popping the keyboard apart. From there, flip out the battery, pop in the new one, put it all back togeather and voila.
Solution 2:
Now if you dont care about your warrenty or it has none (as does mine) there are two contacts on the back of the keyboard which connect to the charger stand. Having took the keyboard apart, solder a wire onto each contact and then solder onto the battery connection contacts taking care to match red to red and black to black. Every time the keyboard is docked it will charge until you remove it. One other thing to note is that the low battery will keep flashing at you now and again (according to logitech you have about 10 mins use left until battery gives up) I have been using it for over 5 hours like this and its still going strong.
Enjoy.
Dec 07, 2007 | Logitech diNovo Edge 9676850403 Keyboard
Logitech diNovo Edge 9676850403 Keyboard Logo
4,168 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
