Question about TORK 401A 24 Hr Mechanical PlugIn Timer 15 Amps 125 VAC
How do you set on and off mode??? - TORK 401A 24 Hr Mechanical PlugIn Timer 15 Amps 125 VAC
Tork, GE, Woods, Intermatic make a series of timers that have pins
The pins push out for OFF or ON times depending on brand
Posted on Oct 16, 2010
How do I set day and date? All else is set
SETTING THE TIME
Note:
When the signal is being received (as indicated by the atomic indicator signal)
you will not be able to make any setting or adjustments to the clock.
1. To begin setting the clock, press and hold the MODE button located on the back
of the clock for 3 seconds to enter the TIME setting mode.
2. The HOUR digits on the display will begin to flash. Press the UP or DOWN button
to set the HOUR in one hour increments. Press the UP or DOWN button as
necessary until the correct hour is displayed.
Note:
If you are in the 12 hour time format, be sure you are in the correct AM or PM
time period. When the "PM" indicator appears on the display, the time displayed is in
the 12 hour period between 12:00 noon and midnight.
3. Press the MODE button again to exit the HOUR setting and enter the MINUTE
setting mode.
4. The MINUTE digits on the display will begin to flash. Press the UP or DOWN
button to set the MINUTES in one minute increments. Press the UP or DOWN
button as necessary until the correct minute is displayed.
5. Press the MODE button again to exit the MINUTE setting and enter the
SECONDS setting mode.
6. The SECONDS digits on the display will begin to flash. Press the UP or DOWN
button to reset the SECONDS to zero.
7. Press the MODE button again to exit the time setting mode. The clock will
automatically return to the normal time display mode.
Note:
If no settings are made within 30 seconds, the clock will automatically return
to the normal time display mode. If this happens, you will need to start the time
setting procedure again from step
SETTING THE CALENDAR
1. Press the MODE button (located on the back of the clock) twice (do not hold the
mode button) to display the CALENDAR.
Note:
The YEAR icon will be shown on the display indicating you are in the year
display mode.
2. Press and hold the MODE button for 3 seconds to enter the CALENDAR setting
mode.
3. The YEAR digits on the display will begin to flash. Press the UP or DOWN button
to set the YEAR in one year increments. Press the UP or DOWN button as
necessary until the correct year is displayed.
4. Press the MODE button again to exit the YEAR setting and enter the MONTH setting
mode.
5. The MONTH digits on the display will begin to flash. Press the UP or DOWN button
to set the MONTH in one month increments. Press the UP or DOWN button as
necessary until the correct month is displayed
6. Press the MODE button again to exit the MONTH setting and enter the DATE
setting mode.
7. The DATE digits on the display will begin to flash. Intermittently pressing and
releasing the UP or DOWN button to set the DATE in day one increments. Press
the UP or DOWN button as necessary until the correct date is displayed.
Note:
The day of the week will automatically set according to the month, date, and
year.
8. Press the MODE button again to exit the calendar setting mode. The clock will
Note:
If no settings are made within 30 seconds, the clock will automatically return to
the normal time display mode. If this happens, you will need to start the calendar
setting procedure again from step 1
Dec 09, 2014 | Westclox 70026A LCD Atomic Digital Alarm...
Tip
SETTING THE DATE AND TIME 1. PRESS MODE (8) TWICE TO SET THE MONTH. PRESS SET...
1. PRESS MODE (8) TWICE TO SET THE MONTH. PRESS SET (9) TO ADJUST THE DESIRED MONTH.
2. PRESS MODE (8) ONCE AGAIN TO SET THIS DATE. PRESS SET (9) TO ADJUST THE DESIRED DATE.
3. PRESS MODE (8) ONCE AGAIN TO SET THE HOUR. PRESS SET (9) TO ADJUST THE DESIRED HOUR.
4. PRESS MODE (8) ONCE AGAIN TO SET THE MINUTE. PRESS SET (9) TO ADJUST THE DESIRED MINUTE.
5. PRESS MODE (8) ONCE AGAIN TO RETURN TO THE NORMAL DISPLAY.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
How do you repair when the flash in DSC-H3 is not responding?
Check if the Flash unit in the Camera is popping up automatically.
Check if the Flash is set to Flash Forced Off. If it is set to Off, then set it to Forced On.
Please check if the Camera is not set to the following settings:
REC MODE is set to Burst or Exposure bracket mode.
Scene Selections modes like:
ISO High Sensitivity mode.
Advanced Sports Shooting mode.
Twilight mode.
Fireworks mode.
Set the flash to Flash Forced On when the mode dial is set to M or when Landscape mode, Beach mode or Snow mode is selected in Scene Selection mode.
This should resolve the issue.
Thanks for using FixYa.
Feb 20, 2011 | Sony Cybershot DSC-H3 Digital Camera
Can't turn on my flash on my sony cyber shot dsc w200. when i try to change the flash it says that my flash settings cannot be changed. what do i do?
Let's try some troubleshooting steps to resolve the issue with the Flash in the Camera. The Flash in the Camera will work only with the settings which is selected.
1. Make sure that the Camera flash is set to Forced Flash ON. (Press the right arrow control button of the Camera continuously to select the Forced Flash to ON.
2. The Flash in the Camera cannot be used when the REC MODE of the Camera is set to BURST or EXPOSURE BRACKET. (To select the REC MODE, select Menu button in Camera Shooting Mode. Set the REC MODE to NORMAL).
3. Flash will not work with modes like ISO(High Sensitivity Mode), Twilight Mode, ISO+(Extra High Sensitivity Mode), Fireworks Mode.
4. Try to set the Flash Mode to Flash Forced ON when the Mode dial is set to M, Landscape mode, Beach Mode, and Scene Mode.
This will resolve the issue with the Flash in the Camera.
Dec 04, 2010 | Cameras
Tipsy clock programming lost leaflet. would like to down load leaflet. bought this inexpensive clock at BB&B.
Hi I was having a hard time with this too, but luckily I found my leaflet.
To set time:
Press Mode 1 time
Press Set 2 times/ press up or down for hour
Press Set again for minute
Continue Pressing Set (up to 6 times) until everything is set
Back to normal mode- Press Mode 4 times
To toggle between 12 hr and 24 hr, press Mode 1 time
To Set an Alarm:
Press Mode 2 times
Press Set 1 times for hour, continue pressing set like you did for the clock.
Back to normal mode Press Mode 3 times
To cancel Alarm Press Mode 2 times and Set 5 times
Jan 16, 2010 | Watches
Shop mode - home mode
Hi.
Try This it might work.
  1. Enter Service Mode - (Press Menu -> Mute -> Power On)
  2. Navigate to SHOP MODE, set this to OFF then select OK
  3. Turn the set off to exit the menu
  4. Turn the set back on and reset the picture settings
  5. Turn the set off and back on again to verify the settings have been stored.
http://dysonmanuals.llc.nu/
Chris.
Feb 05, 2008 | Samsung LN-S2651D 26 in. LCD Television
“My Mode”
My mode allows you to save customized camera settings. My Mode allows you to save different setting configurations. To use the “My Mode” settings, turn the mode dial to the icon shown. The My Mode configuration is selected by the menu selection Mode Menu > Camera > My Mode.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
“My Mode”
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
“My Mode”
My mode allows you to save customized camera settings. My Mode allows you to save different setting configurations. To use the "My Mode" settings, turn the mode dial to the icon shown. The My Mode configuration is selected by the menu selection Mode Menu > Camera > My Mode.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
TORK 401A  24 Hr Mechanical PlugIn Timer  15 Amps  125 VAC Logo
150 people viewed this question
Top TORK Hardware & Accessories Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
pawnpower
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
