Question about Sony CDX-GT300 CD Player
Rear Aux. Problem
I have the GT320. I was told you have to turn on the auxiliary ports in the back from the menu option. Is this true and if so how do you do it?
2 Suggested Answers
  • 6 Answers
SOURCE: sony cdx gt200
I HAVE A SIMILAR MODEL AND I HAVE TO HIT THE SOURCE BUTTON TILL AUX APPEARS MAY BE A RADIO MALFUNCTIO
Posted on Nov 13, 2008
How to turn my auxiliary option on for my pioneer super tuner IIID EEQ mosfet 50w x 4
Should be able to hit source (SRC) button repeatedly and should see it. If not will have to go into menu and turn on
Jun 01, 2016 | Pioneer Car Audio & Video
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
Want to hook up a philips sound bar to my t.v. what cable do I need and where do I plug in at
Which model TV and which model sound bar do you have? Some Sansui TVs have a coaxial digital audio port and a 3.5 mm headphone port; this is true for the SLED2480. Some of the smallest Sansui TVs may only have a headphone out option or no audio output. These jacks will be on the back or the side depending on the model. For some Sansui models, these will be easiest to see when you put the TV on its face (on a clean soft surface) and look next to the base of the TV.
The Philips CSS2123B/F7 has a digital coaxial port, a digital optical port and RCA analog inputs on the back of the unit. It also has a 3.5 mm input on the right side for connection with auxiliary devices (like a headphone out). Other models may have different ports.
Thus the cables you need will depend on the specifics of your devices; similarly the locations of the ports will depend on the models. If your TV only has a headphone out and the soundbar has analog audio inputs, you will probably want a 3.5 mm to RCA audio adapter. There are several options depending on whether you want to use an 3.5 mm audio cable or an RCA audio between the TV and the soundbar. (Pick a cable and then get the adapter to plug into either the TV (M 3.5 mm to RCA FF) or the soundbar (2 RCA MM to 3.5 mm F).) There are 3.5 mm M to RCA MM cables as well.
If your TV has an digital audio outputs, get the correct cable (optical or coaxial) and connect that to the port on the sound bar and TV.
Please add a comment with the model of your TV and soundbar for specific information. I hope this helps.
Nov 30, 2013 | Sansui Televison & Video
I am rigging up an indoor sound system using an old Sony Xplod cassette deck (xr-ca800). I have the unit powered up. I can listen to the radio and tapes, but what I really want is to utilize the R/L...
Those are for the optional CD/MD changer. The deck won't switch over to those inputs unless a compatible changer is hooked up via the bus control. The only way to make this work would require a changer.
Apr 20, 2017 | Sony XR-CA600X Cassette Player
Car radio wont work
First make sure that the AUX option is not set to off. Press A.Menu and then Initial Menu. Then select Aux1 or Aux2. Set this to match the type of device connected to the Auxiliary port, (The options are video, audio and OFF.) (When not in use, these should be set to OFF.)
Then press the Source button and try to set the Source to AUX1 or Aux2. If it still doesn't work, make sure that your device is connected to the jack. If that doesn't help, try a different device cable to connect to the Aux jack.
I hope this helps.
Sep 21, 2013 | Car Audio & Video
Rear auxiliary input source select
Unfortunately, the input on the rear of the stereo are Bus inputs. You must use a controller to use those inputs.
May 13, 2013 | Sony XR-CA600X Cassette Player
How do I dim the lights
Press and hold the Audio/Menu button for more then three seconds. This will take you to the setup menu. Press the Audio/Menu button to go thru each option. turn the dial to change the settings. Options in this menu are: USA or EU frequencies, Local or Distant tuning, Clock on or off while unit is off, Beep on button press, and finally, Backlight Hi or Low.
Feb 22, 2013 | Dual XD250 CD Player with Auxiliary Input...
Sony CDX-GT320 FM / AM / XM Radio / Sirius Receiver missing sat option?
Check the connections between the head unit and the XM tuner. If the connections are good check for power and ground.
Oct 14, 2012 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
I have a kenwood kdc-mp235 unit and I bought a cable to hook smart phone to auxiliary port, I can play a cd or tunerbut no auxiliary! How do I fix this, I push src button but I get no auxiliary selection
You have to have the deck in "standby" mode before entering the settings menu. Press the source button until Standby comes up, then press and hold the menu button. Use the 4-way switch to scroll through the menu options until you get to AUX, then press the switch to the right to turn it on.
I got this from yahoo, click here to view.
Hope it helps.
May 29, 2011 | Kenwood Car Audio & Video
Kenwood Kdc-mp425 will not switch to Aux. Aux cable is connected to the back of the headunit, but no aux option is available on menu for either my ipod touch or my sirius unit. I've accessed the menu from...
Apparently, this auxiliary input only works for a Kenwood CD changer or a sirius radio connection. At least that is my conclusion after finding the same problem. Let me know if you figured anything out on this.
Jun 02, 2010 | Kenwood Sirius KDC-MP425 CD Player
Sony CDX-GT300 CD Player Logo
46 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
