Question about RCA P46924 46" Rear Projection Television
RCA P46924 46 in rear projection tv will not turn on
I have a RCA P46924 46 in rear projection tv. I got it for free and it didn't work. I cleaned it all out with compressed air and it worked. I unplugged it to move some stuff around, and It quit working. Not I can not get it to turn on it has a good outlet it is plugged in to. I push the power button and nothing happens I push the button on the remote and nothing happens what can it be.
  • proudpapa122 Jun 03, 2008
    I will try that and let you know if it works, but as I think about it it makes complete sense. Thanks alot I will try it in the morning and report back
  • Roger Sowers Feb 06, 2009
    I bought a RCA D52W20 Projection tv.Sears came in and said it needed a main board without checking it.Could this be something else?The TV isn't a couple of months old.
    Novelist:
    Champion:
  • 203 Answers
More than likely it has bad solder connections on the circuit board. You could try tapping lightly on power supply/deflection boards to see if it makes contact. Usually I find bad solder on those right under where the power cord plugs in, on the bottom of the board. If you have a soldering iron and solder you could save a few hundred dollars in repair costs, but use caution and make sure all power to set is disconnected. Maybe mark each plug as you disconnect them. Hope this helps. Good luck, Russmann.
Posted on Jun 02, 2008
Tv won't turn on. It turned off after a few minutes and won't turn back on. We opened it up and replaced the fuse.Didn't change anything. A friend said that it just seems to not be getting any...
does the power light flash three times slowly then stay off? If so chances are its just the CP150, cp120 and CP114 capacitors. There is the RCA repair kit by that same name available from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W23 tv
Front Panel Board needs cleaning or replacing Call Encompass Parts 1-800-638-3328 and for just contact switches Call Mats 1-800-628-1118
Jan 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Tv not turning on
replace the flyback you need flyback # 259296 you can get the flyback at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Feb 27, 2009 | RCA D52W19 52" Rear Projection Television
Have a 52 inch rca d52w20 rear projection tv, the tv was on then it just turned off..attempted to turn it back on and heard a sqeaking noise and tv will not turn back on.. please help..
replace the flyback, very easy repair. You need flyback 259296 you can getone at the following link with free step by step instructions with pictures. heres the link read their reviews.
Jan 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Aug 02, 2007 | RCA P52937 52" Rear Projection Television
RCA P46924 46" Rear Projection Television Logo
164 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
