Question about Rockford Fosgate Power 351M Car Audio Amplifier
I have this hooked up and works fine with the key on, but when i start the car, sub light, amp and sub dont come on.
  • 2 more comments
  • Corey Elliott Oct 15, 2010
    I have the amp going to the battery with a fuse, and the remote wire to the solenoid. it has power when the car is running.
    I checked the wires with a aligator clip and light. The power cable and remote wire both light the light, but the light on the amp does not come on.
    The power cable goes to the battery with a fuse, the remote wire is hooked up to the solenoid. The amp works fine when the key is on, but when i start the car the light on the amp dont come on and the sub dont work. I do have power to the amp when the car is running. I checked the power cable and remote wire with a test light.
    I have a new altenator and a Red Top Altima battery. Will a storage capacitor work ? I will get a voltmeter and check it also.
    Novelist:
  • 166 Answers
Double check your power wires. Your power wire should come from the battery. The ground wire should be connected to a good chassis ground and the remote wire connects to the radio remote wire. The remote wire turns the amp on whenever the ignition is on. Sounds as if you might have the remote wire connected to acc power or auxillary power.
Posted on Oct 15, 2010
  • 6,826 Answers
Strange. Because, if the ignition is on, the power from the ignition should turn the sub light, amp and sub on if connected to the fuse box correctly, or the wire that is connected to the ignition that is switchable.
  • Duane Wong
    Duane Wong Oct 15, 2010
    Maybe try to run the remote light to the fuse block for the ignition instead of the solenoid, if that's possible.
    I might consider using a spade that goes into the fuse box, right at the switchable ignition in order to see if that works better than wiring it to the solenoid.
  • 11,800 Answers
You have connected it to the wrong power wire - one that is only active in service mode - first key position.
You should draw a wire directly from the battery (don't forget to add a 40 amps fuse on the wire) to the amps. If you don't want them constantly operational (you will have to manually shut them down) install a relay on the wire with the command coming from a wire from the instrument key position - second position of the key. Use a voltmeter to identify the wires.
  • Azrael SRL Oct 15, 2010
    In that case check the voltages, if they drop below 12 volts (like when you start the car) the protection kicks in and prevents the amp from starting. And use a voltmeter , a test light is useless here.
    If it does drop below 12v then the battery doesn't have enough power for both the engine and the amp - you need a bigger one, charged by a bigger alternator.
    You haven't mentioned the amps output of the alternator - you will need one that is capable of aleast a hundred - the one originally in your car delivers only 55 , far too low - or the capacity of the battery - it should be of at least 85Ah. If you got just standard replacements then definitely they are underpowered.
    A storage capacitor will definitely help, but cannot compensate fully for an underpowered alternator.
I recently hooked up a new kenwood deck put new front and back speakers in. I hooked up a 1200 watt hifonics amp about to plug in my 2 15 inch rockford fosgate speakers rfz1412 and they dont play. All the...
Ok, so I am assuming that the other speakers are working, and it's just the subs that are not, right? If this is the case, start from the source. Make sure the RCA cables are plugged in and not crimped anywhere. Then to the amp, Did you check the gain levels on your amp. That is the knob next to the RCA input on the amp. Also, check the wiring to the subs. Make sure all your + are goinig to +. Sometimes in the "heat" of a good install, you just lose track of those things. When in doubt. Undo all your wiring and start from scratch. Good luck.
Aug 30, 2011 | Rockford Fosgate RFZ1412 Car Speaker
Car amp has power but will not push subs
output blown on power supply - repair by tech required.
Jan 12, 2009 | Sony XM-SD22X Car Audio Amplifier
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
Protection light keeps coming on
Check the wiring between the sub and the amplifier. That's seems to be the only thing left that could cause a problem. If it's shorted to ground or pinched so the conductors are shorted together, it could cause the symptoms you listed.
Oct 01, 2007 | Sony XM-2002GTR Car Audio Amplifier
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
Rockford Fosgate Power 351M Car Audio Amplifier Logo
135 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
