Question about ViewSonic VG810 (Black) 18.1" LCD Monitor
Our View Sonic VG810 LCD Monitor just stopped working. No green indicator light, changed out both the cable and the AC wire, no change. Plugged in another monitor using the same cable/wire and that monitor works just fine. Is the monitor fryed?
  • 11,361 Answers
Probably failed caps in the power supply/inverter boards.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 16, 2010
No LCD Display on Dell Vostro 1700 - 17"
It sounds like you have been pretty thorough trying to resolve the lcd problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 13, 2012 | Dell Vostro 1700 Notebook
I have view sonic VA1912WB 19'' black lcd monitor.. recently im acing problem with it..after i turn on the system the green light blinks and there is no display on screen.. after several(5-6)...
try another monitor on your system if you can barrow one somewhere to eliminate that it may be the computer... if it is the screen check the warranty on it at the view sonic web site... also check the cable from the comp to the screen to see if it is lose. try another cable or if it has hdmi dsub or dvi try those types as well. it may have a lose connector on the one your using...
May 20, 2011 | ViewSonic VA1912wb 19" LCD Monitor
Why my computer is not turning on my monitor but the cpu is running
Need more information:
1. Are you sure the monitor is plugged into power?
2. Are you sure the monitor VGA cable is connected to the computer completely?
3. Is there an indicator on the monitor (a light).
4. When did it stop working? What changed?
Sometimes the power cord in the back or bottom of the monitor comes loose. Ensure all wires are securely connected.
BobB
Mar 24, 2011 | Computers & Internet
View sonic vx900 monitor - screen display comes on for a second and then goes dark; green light on monitor - all cables and power seem to be fine
It may have backlights inverter board problem, check the two surface mounted fuses, also can be bad lamps. Also verify that the AC adapter is putting out correct voltage with load.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX900/#!cpZZ1QQtppZZ20
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 29, 2011 | ViewSonic VX900 19" Flat Panel LCD Monitor
View Sonic VA720 monitor goes out after power goes
replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Nov 15, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
My view sonic monitor does not work properly
sounds like the power supply inside of the monitor is going bad. did you replace the cable from tv to the wall?
Oct 16, 2009 | ViewSonic VX922 19" Monitor Flat Panel
View sonic g220f
If both ends of the cable are plug in type, any monitor cable with a 15 pin D connectors will work.
Search internet for VGA cable.
Jul 30, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
View sonic flat screen monitor
Problem seemed to be a short in the power cable to the monitor. Replaced the power cable and for the time, the monitor is working correctly.
Jul 07, 2008 | ViewSonic VX924 19" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
ViewSonic VG810 (Black) 18.1" LCD Monitor Logo
53 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
