Question about Kyocera Office Equipment & Supplies
My Kyocera laser printer is printing blurry any suggestions, I've cleaned what I could but no luck.
SOURCE: kyocera printer problem
First I would recommend cleaning the printer. When you change the toner there is sheet of paper that comes with the toner cartridge that explains how to properly clean the printer. If you do not have that handy, there is a panel on the left hand side of the printer that you need to open. Once the panel is open you will see the waste toner bottle; leave it in place. Above and to the right of the waste toner bottle will be a green nob. Pull this green nob slowly in and out three or four times. This will clean the charging wire. Next underneath the green nob there should be a piece that looks like a rectangular box when you pull it out. I believe it is green as well. This is the charger grid. With each toner you should have gotten a small slate blue box with a plastic lid that has a piece of felt under the plastic lid. Remove the lid and this should slot in under the long, rectangular charger grid. Move this back and forth three or four times and than remove the slate blue box. Gently push the charger grid all the way back in and close the access panel.
If this does not fix your problem I would recommend getting service from wherever you purchased the printer as you may have damaged the drum.
Let me know if you have any further questions.
Henry
Posted on Aug 15, 2008
  • 26 Answers
SOURCE: Hi its a kyocera laser
Try to input the ip address in the address bar of a browser, you will see the web page of the printer with the toner gauges.
Posted on Feb 17, 2009
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
  • 46 Answers
SOURCE: Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Log into your pc as admin and under the driver properties change from kpdl to pcl5
Its a combo of a problem with adobe reader and the KPDL driver
Posted on Jun 11, 2009
  • 46 Answers
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Posted on Jun 12, 2009
WHITE LINE THRU PRINT ON KYOCERA MITA KM-3035
clean the LASER glass for that color, if you dont know what that is get a tech out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 22, 2016 | Kyocera Mita KM-3035 All-In-One Laser...
Epson dx8450. Its about 2 years old at this stage, but hasnt given us any problems till now. When printing the colours come out as if sepratly and ghost on top of each other. Like, if I printed a circle...
click on the printer icon...locate the tools to configure your printer...click maintenance...click the nozzle check to repair the misalignment...then test...when you see the printed lines...click clean to clean it...
If the problem still exist...you need to see printer technician to resolve the problem
Sep 21, 2011 | Office Equipment & Supplies
Whenever our Kyocera Fs-720 printer prints it leaves dark splotchy smudges all the way down the page, any suggestions?
Your printer probably is due for a maintenance clean, which can be done by a certified printer technician.
May 28, 2010 | Kyocera FS-720 Laser Printer
The Color is printing blurred?
Could be down to dirt contamination in the laser scanner
Oct 10, 2009 | HP Color LaserJet 2600n Printer
Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Jul 09, 2009 | Kyocera Office Equipment & Supplies
Dark spots on my paper
is there a corona wire sliding cleaner on the drum assy? if so it should be firmly at the correct end of its travel - on some printers if it is inboard it will print aline down the side
Apr 18, 2007 | Kyocera Mita FS 3800 Laser Printer
101 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
