Question about GE Microwave Ovens
HVM1540dn1ww: Touch screen stopped working. Digital clock is on and correct but no buttons will work. Microwave was made in 01-08.
Try unplug mic.
Posted on Oct 15, 2010
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
Will not start
I have the same problem, diagnosed as bad touch screen panel.
Apr 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Set clock
Does it have a clock button. If so simply push clock, input the time then clock again.
Nov 28, 2009 | Microwave Ovens
Bottons on microwave do not work
HI, the touch pad board has failed. you will need to replace this damaged board asap. this will correct the issue.
Sep 27, 2009 | Microwave Ovens
Key pad stop working
HI. this will happen over time if the microwave is used heavily and if it is over three years old. this key pad is attached to a smart board that you will need to replace. replacing the smart board will fix this issue.
Jun 06, 2009 | GE Microwave Ovens
Dacor Touch Screen is flickering and doesn't respond to touch
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Mar 31, 2009 | Dacor DMT2420SS Microwave Oven
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
Sharp 1100 w Microwave Model R-420BK - Clock display not working correctly
This is a problem with the control panel assembly, and we repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 13, 2008 | Sharp R-420DK Microwave Oven
Kenmore microwave
The Keypad is a Circuit.Each of the Function Buttons is a switch. The same "Touch" Techinology as is used of your TV Remote Control Pad or your Telephone. It would appear that your Keypad Circuit is Open, not allowing touch commands to reach the Control Board.The Keypad will have to be replaced. Best done by a Professional. I have seen "Rare" cases of a defective Door Switch causing such symptoms.
Jan 26, 2008 | Microwave Ovens
Microwave Ovens Logo
517 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
