Question about HP PSC 2410 All-In-One InkJet Printer
On startup, my ink cartridge on hp2410 is stuck to the right. I cannot move it
  • HP Master
  • 7,733 Answers
The ink cartridge cover is not latched. what do i do
The cover is really not needed. I removed mine to install a CISS ink system.
Feb 09, 2016 | Epson WorkForce WF-7620 Wireless Color...
Ink cartridges won't move to the left, error code 6000
You will need a new carrage motor for this, better off with a we printer.
Jan 09, 2012 | Canon Pixma iP2600 Photo InkJet Printer
Carriage for the ink cartridges is stuck, the carriage wont move to the middle so i can change the ink. i turned off the power & then turn it on , the carriage just move a little from the right and...
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X2600 InkJet Printer
It says paper jam but we do not see any paper anywhere
did you switch the machine on and off
one of the paper sensors may be stuck pr damaged
Feb 14, 2011 | HP Officejet Pro 850 InkJet Printer
I want to print some document but the screen in my hp2410 said" remove and check cartridge in right stall.??? what should I do?
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 04, 2010 | HP PSC 2410 All-In-One InkJet Printer
WRONG CARTRIDGE and Printhead does not move MP780
your printer ink cartridge can not access (move to middle) when you open up the cover, you may try
1) try to open right side cover you move the cartridge by hand (power off) to middle position, then take out the cartridge and reinstall it then power on, the cartridge moving right, you may open up the cover again if the cartridge go back the middle position which means your printer works normal. still stop moving go next
2) check the cartridge initcial sensor at righe side, the cartridge moving to the end of right should be touch this sensor, find out it and check there is good touch (click) by the cartridge body. adjust the sensor position maybe needed.
3) cartridge is stucked sometime also check the cartridge moving rail hard moving, need to drop oil to lubricate.
Feb 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Ink cartridge assembly wont' move
Go to the authorised service center and they will do the needful
Jan 17, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Cannot get ahp58 ink cartridge to fit a hp2410 printer,the box that it come in said it would fit; how do I get it to fit?
The #58 cartridge goes into the right side...remove the black cartridge and insert the #58 cartridge. This give the printer a wider range of colors when printing photo.
Nov 22, 2008 | HP Office Equipment & Supplies
Really really slow printing!
I had the same problem with a hp 4315 it was a bad ink cartridge causing the problem. It did the same for a different hp printer.
Feb 19, 2008 | HP DeskJet 670c InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
69 people viewed this question
Seeker5211
Seeker5211
