Question about Gold Medal 2131 Antique Gay 90s Pinto Pop Popcorn Maker
Our popcorn machine is blowing the circuit when the kettle heat is turned on. Is there any way to fix it or any way to just buy a new kettle?
Mine is doing the same thing. Did you get yours fixed yet? If so, what was the problem? Its got to be the wiring. If you take off the bottom square wiring cover access, you will see the two main wires and a grounder all connected. Sometimes the connectors melt with the heat. Maybe that is what is causing the short.
Posted on Oct 21, 2010
Trying to find kettle wiring drawing 3255
To order a manual from the factory the part# is 67834. Depending on how old this is , those kettles and or similar design had a issue with the nut comming loose that holds down the thermostat thight to the bottom of the pan. The loose nut would then bounce around in there until it touches a elect.connection and ground at the same time. It will short circuit the kettle and end up welding itself in place . so when you turn the kettle on it trips the circuit rite away. you have to dissasemble it and remove it . there is a new locking type nut avalible to replace it.
Jan 11, 2016 | Gold Medal Kitchen Appliances - Others
Can I replace the heating element on the popping kettle?
Refer this issue directly to the manufacturer/distributor for repair/replace advice.
Jan 23, 2015 | Kitchen Appliances - Others
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Oct 01, 2014 | Gold Medal Kitchen Appliances - Others
Will thermostat stop kettle from overheating and blowing thermal fuse
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
Jan 09, 2014 | Nostalgia Electrics KPM-508 Popcorn Maker
After clening the kettle it blows breakers
You got the Heat element and or thermostat wet. Open the kettle to expose the electronics and let it dry for days. try again it might dry out.
Or you will need to replace the heat element, thermostat, and probably the wires. if it hasn't dried out by now.
Dec 26, 2012 | Paragon 1911-8 Popcorn Maker
I DO NOT HAVE COOKING INSTRUCTIONS FOR MY KPM-508 POPCORN POPPER
The instructions say make sure kettle motor is plugged in. Turn unit ON with switch on crown of machine. Allow unit to run for 3-5 minutes to heat up kettle. Turn unit off. Add 2 teaspoons of your favorite popcorn cooking oil to the kettle. Then add 1/4 cup of popcorn kernels to the kettle. Turn the unit on and close the door. When popping sound slows down turn the unit OFF. Flip the kettle over with the crank handle to empty the kettle. Repeat process until desired amount of popcorn has been popped.
Jun 09, 2011 | Nostalgia Electrics Helman Group KPM-508...
The popcorn gets stuck in the kettle until it burns
I have a Popcorn machine from Nostalgia too that had this problem. I cleaned it out and everything but it still had the problem of the it getting stuck. After days of analizing, I found the solution. after a while the ceiling of the popcorn machine starts to fall in, lowering the handles of where the kettle goes. making the knob that turns being lower that the one that makes it turn, causing it to get stuck, all I did is add so leverage so the kettle is once again at the same level or higher. Making it turn with greater force and not getting stuck. In other words make sure the turning mechanism is leveled and not one lower than the other. preferably the kettle part being higher.
Jan 09, 2011 | Nostalgia Electrics Helman Group CCP-509...
Kettle does not work
you have probably re-wired the switch incorrectly or there is water in the wiring and the circuit is shorting, causing the fuses to blow. Also, is your electricity supply 120v or 240v?
Jun 15, 2009 | Benchmark 11065 Popcorn Maker
Trips circuit when you turn on the Kettle heat
When the fuse blows see what else in the house is out, maybe you have the circuit overloaded. Try putting the popcorn maker on a different unused curcuit to see if it still blows. Then you will know if it is the popcorn maker.
Dec 09, 2008 | Gold Medal 2086 Popcorn Maker
Gold Medal 2131 Antique Gay 90s Pinto Pop Popcorn Maker Logo
333 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Coss
Ted Maxwell
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
