Question about Xerox Phaser 8500N Printer
I am printing directly from my PC to a phase 8550 printer. However, lately I have encountered timeout error and then the graphic image printed out page after page of funny character. What is the problem? JT
  • Xerox Master
  • 13,433 Answers
Hello, and thanks for using FixYa.
There seems to be a communication problem between the printer and the pc. I'd recommend that you uninstall the printer from the commputer, you can do so from start -> control panel -> uninstall programs or "add or remove" programs.
After you have removed the printers software, if any exists. Then go to the printers and faxes folder. Which you will find from either start menu or from start -> control panel -> or in some cases it might also be in My computer.
Once inside the folder, right click on your printer and select delete. Also disconnect the printers usb canble and make sure there are no other printers with the same name installed there.
Now restart the computer, and being to install the printer back to the computer like you did when you purchased it. Insert the cd and run the setup. if you no longer have the disc you may obtain the software from http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=8500_8550&Xlang=en_US&Xcntry=USA
after you have installed the printer it should work normally again.
Please let me know if you require further assistance or if you have any questions.
Thanks,
Ekse
Posted on Oct 15, 2010
Service code interrupt
Error type T11 [Pressure-control motor lock]
T11-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset or switch on power again
Error point Error conditions
600
Timeout error for reducing pressure (OFF -> ON) during print-pressure home
positioning.
601
Timeout error for increasing pressure (ON -> OFF) during print-pressure home
positioning.
602 The print-pressure limit sensor does not change during print-pressure operation.
620 Print-pressure operation was called with the print-pressure motor locked.
621
Incorrect print-pressure operation timing (print-pressure operation command was
received when the print-pressure should not change).
622 Sensor A is ON and sensor B is OFF during movement from area A to area D.
623 Either sensor A or sensor B is ON during movement from area D to area A.
624 The current area data is undefined.
625 The target area data is undefined.
626 Timeout during relative print-pressure movement.
Error type T12 [Master-disposal-section motor lock]
T12-***
!!System Error!!
Press Reset Key
305
The master compression sensor does not go ON within 6.5 s after the master
compression motor operates in the return direction.
306
Master compression sensor does not go OFF within 2 s after the master
compression motor operates in the compress direction.
307
compression motor operates in the compress direction, and the mastercompression-
motor limit sensor cannot count up until the compression-limit
position.
309
The master-compression-motor limit sensor does not change within 200 ms
during compression operation.
hope to be of help
Sep 27, 2013 | Riso RP 3700
I get a timeout message at the end of a print run
Toggle through the menus on the printer to the "Sys Config Menu" and turn OFF both the "Manual Timeout" and "Timeout in Job".
As a note, we only have this issue crop up when our printer is accessed through an Apple Time Capsule. When it was directly attached to the computer, or accessed directly through IPP we had never had the error page print.
Jun 03, 2012 | Oki Electric Industry B431dn Printer
Brother printer taking too long to eject a printout
I'm not sure I understand your question. It sounds to me like the printer is working properly. An inkjet will spit a text only page out faster than a page with graphic data on it.
Ink Jets print the images in a "Swath" pattern. This is what gives the page the step motion on exiting a printer.
Now laser printers, since they are intelligent printers, will build an image and then transfer the image, fuse the image and eject the page in one smooth operation.
But lasers would require a "Print Page" command from the datastream to force the page ejection or trying to print outside of the no print area on the page.
For example a PCL 5e datastream would issue a hex 0x0C command to eject the page.
PostScript wouold issue a "Showpage" command.
Don
Jan 29, 2010 | Brother MFC 4650 All-In-One Laser Printer
We use it to print out final invoices & everything prints fine except the bottom right hand corner where the invoice total is listed is left blank & prints a second page that reads "ERROR:timeout,...
It is a postscript error, refer to here
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi?new,kb=Phaser_6250,company={5AC8CA72-62D5-4658-8D6F-D2F393C98A63},ts=xo,ques=ref%28security_level%29:1,ques=ref%28Country%29:45,/,case=R1002035441
Jul 15, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8550 printer fault 37,008.44:25860
This is a pre heater error.
I would make sure the printer is connected directly into the wall and not into a power strip or UPC as these devices may create momentary AC voltage sags that could cause this error. If power levels going into the printer are good, you will need to contact Xerox for support
Jan 13, 2009 | Xerox Phaser 8550DP Printer
Message ID . . . . . . : CPA403D Severity . . . . . . . : 99 Message type . . . . . : Inquiry Date sent . . . . . . : 12/11/08 Time sent . . . . . . : 15:13:47 Message . . . . : Operator action required on...
This is a JetDirect error and can be cured by adjusting the IO and Idle timeout values. Set the IO Timeout (or Job Timeout) to 300 seconds ( 5 minutes) and set the Idle Timeout to somewhere between 900 seconds (15 minutes) and 3600 seconds (1 hour). Setting the IO Timeout (or Job Timeout) and Idle Timeout to 0 does not disable them. It causes the printer and/or print server to timeout immediately. The IO Timeout can typically be set through the control panel on the printer, or it can be set using the HP JetAdmin Utility. The Idle Timeout can be set by TELNETing to the TCP/IP address for the printer, or it can be set using the HP JetAdmin Utility. The HP JetAdmin Utility can be downloaded from HP's Web site, www.hp.com.
The print job is defaulting to tray 1 so you will need to change this at the application and printer driver admin and not at the printer itself.
Dec 11, 2008 | HP LaserJet P4014n Printer
Time Out Error
This is from Xante's 3G Manual (downloadable via PDF)
"Printer Timeout The Timeout feature allows you to select the number of seconds the
printer waits for additional data before cancelling a job and returning
to the READY/IDLE state.
Set Timeout from the MISC:TIMEOUT configuration menu. The
factory default of 40 seconds (40 Sec) is an average setting. Set
timeout according to the type of files you send. Use a low setting for
small, simple files to prevent an indefinite tie-up on one job. Use the
300 or Never setting for large files, such as graphic intensive or CAD
(Computer Aided Design) files, to allow enough processing time.
With the NEVER selection, the printer does not timeout; it waits
until it receives additional data or until the printer is reset."
Here is the address where you can download the manual:
http://www.xante.com/support/aw3g/manuals/PDF/complete.pdf
Nov 15, 2008 | Xante Accel-a-Writer Laser Printer
Problems with printer settings
Interesting. I tried printing a simple 3-page Excel spreadsheet sent my by a colleague to my 8500DN from Microsoft's Excel Viewer and got a timeout error formatted as follows:
ERROR: timeout
OFFENDING COMMAND: timeout
STACK:
42
-mark-
(84,160)
No idea what this means, but resetting the network parameters (even though I use USB connection) from the printer's front panel cleared the problem. The printer would print nothing else from any program until I performed this reset. Wonder if Excel futzes with settings and printing somehow?
Oct 14, 2008 | Xerox Phaser 8500/DN Printer
Rimage Everest III printing quality issues
Hi Jay, do you have any idea how many discs have been printed with this Everest Printer?
Your issue sounds like a hardware error, not an issue with the software you are printing from. Most likely the printhead needs to be replaced, or the control board. Printhead replacement costs approx $1200.
- techware dist
Apr 14, 2008 | Rimage Everest Autoprinter Thermal
Phaser 8550 cyan doesn't print
If you go to the Xerox.com site and click support and drivers. enter phaser 8550 and there is a printhead update you need to get, You have to fill out a form.
That may be your problem since there is no fault code.
Apr 13, 2008 | Xerox Phaser 8550DX Laser Printer
Xerox Phaser 8500N Printer Logo
20 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
