Question about Sony Playstation 3 (PS3) Console
Have ps3, backward comp, got in dec 2007, playing online, cll of dty2, if shut down, hit power button and got-short yellow,then blinking red, would not turn on, tried again, got blinking red,then red. fans working and syst cool to the touch. P.S. system did upgrade just before it happen, sent to sony-$178 to fix, they said sounds like hardware? still waiting for syst back. also clld sony and recording gave me tracking# and said to go to usps.com, it is a fed x #, they **** junkm33@yahoo.com
  • 104 Answers
Im sorry
Posted on Oct 15, 2010
Fully backwards compatible ps3 shuts down with 3 beeps and flashing red light when trying to play ps1 games
Hmmmnnn, consider the reason they pulled the rev compatible system off the market. It is possible to be getting the symptoms of YLOD without it actually happening with some games. The older games spun faster(sometimes) and made the system work harder. It could be heating up and shutting down right at the point of failure. I've seen 2 different revers compatible systems YLOD the same way. Good luck.
Apr 06, 2013 | Sony Playstation 3 (PS3) Console
Tip
Fix the 80010514 error on your PS3
If your Play Station 3 (PS3) gets the 80010514 error somewhere, you can try this to resolve the problem:
1. Make sure that the power indicator on the Play Station 3 system is solid red. To do this, press and hold the power button until the PS3 beeps and the light blinks. Once the light has turned solid red, turn the power switch in the back off.
2. Turn the switch back on, then press and hold the power button.
3. Keep holding the power button even after you hear a short beep after 5 seconds.
4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
5. Press and hold the power button again.
6. Continue holding the power button even after you hear a short beep after 5 seconds.
7. Release the button when two short beeps are emitted after 7 seconds.
8. As instructed by the on-screen message, plug in the controller and press the PS button
9. Select restore Play Station 3 system.
This should not affect any of your save games, demos, etc. but just to be safe you might want to back up to an external USB hard drive.
To backup saves, go to the Play Station 3 Save Data Utility, select the save you wish to copy and hit the Triangle button. Copy should come up as one of the options. If it does not then the save game is copyright protected and can’t be copied. If you can copy it, make sure you have a USB drive attached and copy it to that.
on Feb 02, 2010 | Video Game Consoles & Games
Hi, i have been playing online with my ps3 this evening when my console bleeps 3 times and shuts off instantly,it has never happened before and has happened 3 times tonight. The red stand by light flashes,...
Hello there toucss
If you have the red blinking light then you have the RED light of death AKA the RLOD.
The light is a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the RLOD.
WHERE TO GO FROM HERE
Option 1 - Call Sony
In warranty the Price is Free, out of warranty the Price is $150, the whole process is 4-6 weeks
You can call Sony and they will collect the PS3, repair/replace, and deliver the PS3 back to you
Option 2 - Fix it your Self
You can use a PS3 fix manual to get this fixed easily and at home using household tools you probably already own.
Click Here For The PS3 Manual which has helped so many people like you.
Good luck
Best regards
Peter
Sep 15, 2011 | Sony Playstation 3 (PS3) Console
I was in the middle of playing a game and my ps3 system tottaly shut off and beeped then turned back on. A little while later it did it again but this time it will not fully turn on it just turns on for a...
ou have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself as some would suggest.You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
IT CAN BE FIXED
FOR THE DISC THAT'S STUCK INSIDE?
If you have a unit that is not backwards compatible, any non 60g or 80g then you can retrieve your disc.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
When I turn on my PS3 it turns yellow then immediately shuts down
Its the yellow light of death, its an over heated ps3. Theres not much you can do about it, take it to sony or a computer fixing shop and get the console fixed. These can be fixed at a price of around £35. If you cant get that, get a new ps3, its what i had to do.
Aug 08, 2009 | Sony PlayStation® 3 (60 GB) Console
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Red light green light yellowlight red blinking light
From what I understand its a problem with the backwards compatibililty(the engine/drive that lets you play ps1/ps2 games)on the 60g.Sony says they have never heard of this problem yet these models are no longer in production.I have had mine for 2 years and it died today,same problem.
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
My PS3 wont turn on...
Try holding down on the on button till it resets the settings, that may turn it on
May 05, 2009 | Sony Playstation 3 (PS3) Console
Power light blinking red not playing or edjecting
There are a few small things you can try.
Check out my guide here:
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 26, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
37 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
