JetFlash TS16GJFV10 USB Device had a write protection issue it's not possiable to copy,past and format any data from my usb 16 GB stick and it also without protection seureity buttone so. how i can solve this issue without lossing any data from my usb stick if it possiable?
SOURCE: HOW TO FORMAT A WRITE PROTECT USB DRIVE
MY KINGSTON DATA TRAVELER SAY WRITE PROTECTED HOW CAN I FORMAT IT CAUSE WHEN I FORMAT IT DIRECTLY IT SAY DEVICE IS WRITE PROTECTED BUT MY USB DEVICE DOES NOT HAVE THAT KIND OF SPECIFICATION TO HAVE A WRITE PROTECT DISK.
I had same problem. I fix it with suggestion of 1st guest. I download program from site http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip, and program formated USB and he work fine now. TY for advice.
Posted on Jul 24, 2008
Dipu007
  • 2110 Answers
SOURCE: 2GB Disk but only 357MB is writeable
Have tried formatting it..If not u have to format it first...And see how much free space in property of usb device...
Posted on Dec 18, 2008
Ashu2748
  • 62 Answers
the drive isnt write protected the usbport or the connection is loose so that the computer is showing the drive as read only drive also you can format it using command and also setting off the read only attribute that may have been put by a virus also softwares like usbcillin makes pen drive writeprotected take care
Posted on Jan 19, 2009
  • 7 Answers
try this tool HP USB Disk Storage Format Tool!!
Posted on Feb 25, 2009
SOURCE: I am having Jetflash v10 16 gb model 'Transcend' USB Flash Drive.
Try formatting the drive using NTFS and re -copy your stuffs again. If it fails to copy as you want, then delete the partition and format it again .
Posted on Mar 26, 2009
My transcend 4 gb pendrive is write protected .how can i remove the write protection
When formatted, the disk is write protected (there is damage to the firmware)
Damage to the firmware, there are two types of
1. Damage the firmware, data can be saved
2. Damage the firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair and repair the firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to the flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
Nov 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My trancend 8 gb has become write protected. I used the regidit formula but the problem continued
Flash drive is write-protected, meaning there is damage to the firmware. To repair damaged Transcend firmware, use JetFlash Online Recovery software.
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download)
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
I hope this information helps.
Before repaired
After repair
Oct 06, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When ever i try to copy a file on to my pendrive ,a file pops up saying that it is a write protected drive .how am i to remove this write protection?
try this one, hope it will work on your memory stick coz i tried this and i was able to format my write protected memory stick smile.gif
use a computer with XP OS.
right click 'my computer'
select 'manage'
then select 'disk management' to format ur memory stick. but sad to say, all data will be lost, am pretty sure you know it
Jun 10, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
The usb i have plugged in the computer is 4 gb transcend flask device.I have been using it for about 1 year .The data in the pendrive can be accessed by the computer but when i try to copy/paste the...
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pendrive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Nov 16, 2009 | iLO (2 GB) MP3 Player
Transcend JetFlash V60 16 GB Pen Drive not working properly
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that its Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32.
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 05, 2009 | Electronics - Others
My usb pen drive has became write protected while i was copying some data
You can try to go to my computer ( with the pen in usb slot ) right click usb pen and then format the pen. This should clear it. It sounds like one of the files you transferred is write protected.
May 04, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transend 16 gb formating problam
2. Format pen drive
Apr 04, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend pen drive 16gb+write protected
Dear,
No, problem
Just copy the whole data of pen drive to PC. Now format the pen drive
and paste the data from PC to pen drive again. It will work fine then
Thanks,
Regards,
Rakesh Kumar
Apr 01, 2009 | Electronics - Others
Dear Friend,
My Jetflash also writeprotected, there's no any solution for this in internet but I could solve this problem,
what you can do is, make your write protected drive "shared", that means go to my computer---> then rigtclick on flash drive---> click sharing & security---> check both "share this folder on network" & "allow users to change my files" ,apply setting then you'll be able to format your drive.
I could do it,
let others to know about this solution. Because I also suffered from this problem.
Amila--> +971559473812
asfonseka@yahoo.com
Feb 26, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Jan 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
