Question about Gateway 450SX4 Notebook
Black screen on gateway 450sx4 laptop
The screen went black when i went to move the laptop on my lap, and the ac adapter slipped out of the back of the laptop. the screen has been black ever since. the computer starts up and i can hear the fan, but the screen is just black. thanks for any help.
  • ksheralt Oct 30, 2008
    Turned on the computer, which has no battery power, and the AC adaptor wasn't plugged in all the way. It was on for 2 seconds, and then shut off. When I turned it on with the AC adaptor in, the screen was pretty much black...I could barely make out the background. The computer store told me the backlight went out.
  • martzfamily Jan 22, 2009
    My screen is black I can make out a faint view of stuff when it is loading. I can plug it into an external monitor and I can see it fine on there.
Inverter board. Promise.
Posted on Mar 10, 2009
Get a new motherboard
Posted on Sep 16, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Sounds like ,audio card went died or mite be screen has shorted out try hooking it up an orther screen and see if it boots up if so either viedo screen card or screen it self
Posted on Jun 02, 2008
I have a Gateway NV7802u laptop computer. I was using it I needed to move to another room so I put it to sleep unplugged the AC adapter, by the way I am using the AC adapter because the battery has like a...
Have you tried holding the power button down until it shuts down completely, then unplug the AC adapter, remove the battery, put it all back together then try powering back up?
Mar 27, 2013 | Gateway NV7802U Notebook
Hi: My Aspire 4710Z was not shutting down properly. I pulled out the battery to turn it of. Now, when I put back the battery after few hours, there is no power in my Lap top. Screen is black and now...
Remove the battery and the AC adapter from the laptop.
Press and hold the power button for 60 seconds then let go
Plug the AC adapter only back into the laptop
Now press the power button on the laptop
If it now boots properly shut down the laptop and insert the battery
Now push the power button again
If it now fails you may have a bad battery
Mar 05, 2011 | Computers & Internet
Yea i have a gateway 450sx4 laptop and when i turn it on it stays black for a while and when the screen finally turns on it blurry and its different colors and it just shows lines how can i fix this?
It's likely that your screen is "fried" (faulty) ... try to connect your laptop to an external VGA monitor, and see if the screen shows up (on the external monitor) properly. You may have to toggle the output display (device) from computer screen to external monitor ..using Fn+F3.
If it displays on your external monitor properly, it means your laptop screen is no good. You can replace the laptop screen, or just continue to use the external monitor.
If it does the same (blurry & different color, etc.) on your external monitor, then, your video card/module on your laptop is bad. This usually happens less often.
Aug 11, 2010 | Gateway 450SX4 Notebook
Screen is black
The cable is dislodged or you have a failing lcd.If you want to repair this yourself.Check online for a replacement cable and a Lcd too.Then you will have to open the Lcd Bazel to remove or check the cable.Make sure when you attempt this there is no power attached ,battery and Ac Adapter.
Good luck
Nov 02, 2009 | Gateway 450ROG Notebook
My 450sx4 mysteriously changed the screen resolution from 800X600 to 640x480 & now won't let me change it back. any suggestions?
It is definitely a drivers problem. Some driver files have gone corrupt and you need to reinstall the Video/Graphics driver on your computer. Most probably the drivers would be in the Disk that you got with your laptop, else you can download the latest drivers from the Gateway website.
Aug 08, 2009 | Gateway 450SX4 Notebook
Laptop shuts down when moved around. I have a Toshiba A135-S4467 and yesterday when I went to pick it up and set it on my lap it shut down leaving the power button flashing orange. when I pressed the...
Sounds like a Battery - AC Adapter problem. Do you have an Icon showing your battery level?
Do you have Windows XP? I'm guessing you do because of the memory upgrade.
If you have XP, go to Control Panel - Power Options and check you battery. Choose to show in task bar.
If you have a AC Adapter, the BIOS on your laptop will NOT charge the battery, but it will show that you are on AC (unless it's completely dead)
I'm guessing that if you only had 1g of memory, you have a pretty old laptop, and you probably should purchase a new AC Adapter, and a new Battery.
Apr 09, 2009 | Toshiba Satellite 1805-S274 Notebook
I want to disassemble Gateway 450SX4
Nowhere: Only HP and IBM and DeLL offer parts schematics for their laptops. But if you take a look at some of those,you'll have a really good idea how to work on your Gateway,because they're all very similar.
Mar 07, 2008 | Gateway 450SX4 Notebook
450sx4 gateway laptop troubleshooting.
Does it do this when it's running on just the battery with no AC ,or does it only do it when running on ac adapter ? If it only behaves this way when using the ac adapter,then the ac adapter is bad.
Can you hear your fan running in your laptop ? If not, your processor may be overheating(which would also cause problems like this).
However,If it behaves this way when running only on battery,then I would think you need to replace one or more of your memory chips (DIMM'S).
Feb 08, 2008 | Gateway 450SX4 Notebook
Computers & Internet Logo
743 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
