Question about PC Chips M955G Motherboard
LA PC SE REINICIA CONSTANTEMENTE Y NO PRENDE - PC Chips M955G Motherboard
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: pc se pega constantemente ,sobre todo cuando intento conectarme a internet
google translate
pc sticks constantly, especially when trying to connect to internetno is that it can be the problem ... has the antivirus funcionandoa
that can not be the problem ... has the full funcionandoa antivirus .... I reset the bios thousand times ... formatted with different versions of Windows XP and the problem persists
answer
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
if still no luck
i
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
games scroll to bottom of screen (task bar) select task manager applications you will see whats running if you see anything you
dont need running select end now also under processes you might have a virus slowing you down and users you will see who is using your computer
hope this helps
Posted on Jul 14, 2012
Mi ranger prende i se apaga a fuerza le prende el foco de la pila y la auja de la carga esta abajo no se que es alguien save
Diana si se enciende la luz de la bateria lo mas comun es que necesites remplazar el alternador asumiendo que la correa este en buenas condiciones
Aug 07, 2015 | Cars & Trucks
Tv green light flashes
cuando le dan a prender prende el led verde y la tv prende prende por 3 segundo presenta en la pantalla el letrero sony y se apaga la tv y el led verde. luego prende el led rojo 2 parpapadeo pausa larga 2 parpadeo y pausa larga y se repite
Dec 08, 2013 | Sony BRAVIA KDL-40V3000 Television
Jeep liberty 2004 se enciende una luz en el lado derecho del tablero de color naranja q es
Exactamente cual es la luz que ve en su tablero...
Comentenos para poder darle mayires detalles.
Nov 24, 2011 | 2004 Jeep Liberty
Tengo un mp3 gogear sa 1945/55 y no prende ,cuanod lo onecto al ordenador la pantalla se pixela y no lo reconoce use el philip desvice manager y ahora no prende , no lo reconoce , y cunaod lo conecto usb...
yo tenia el mismo mp3. es un problema de los phillips. no ay mucha solucion para esto. trate de apretarle el reset button si esto no funciona trate de llamar a la compania. alomejor el device se le cayo y por eso no funciona
May 03, 2011 | Philips GOGEAR SA6045 MP3 Player
El proliant ml370 g5 no prende. los leds aparecen de color rojo, los coolers prenden y apagan constantemente
Abre la tapa y comprueba que el ventilador de la CPU está firmemente sujeto y presionando la CPU.
Feb 28, 2011 | HP ProLiant ML370 G5 (458341-001) Server
Sony pcv-w10 no puedo entrar a windows, la maquina se reinicia
intente de golpear F-8 en inicializa y entonces va al modo seguro si eso trabaja entonces usted puede hacer un disco de escSony pcv-w10 no puedo entrar a windows, la maquina se reinicia áner para encontrar el problema si que no trabaja entonces trata F-8 y última configuración buena de la consola de recuperación
Jan 23, 2010 | Sony VAIO PCV-W10 PC Desktop
SE PRENDE EL CHECK ENGINE Y SOLO SE APAGA CUANDO
dé vuelta a la llave de ignición 40 veces de apagado a encendido
Dec 12, 2009 | 1997 Mercury Villager
MI COMPUTADORA IBM NETVISTA SE REINICIA
The problem is in your RAM, try to change, for new ones
Jun 04, 2009 | IBM NetVista A21 PC Desktop
Se reinicia a cada rato
tengo un problema con el ADF de una Xerox Pro 215 cuando quiero copiar algo se van las hojas en fila no juantas sin separarlas una por una que podria ser el prolema alguien podria alludarme
Dec 03, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
PC Chips M955G Motherboard Logo
105 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
