SOURCE: Tag Heuer Formula 1 Mens watch
This is not a cheap watch....You should send it to a qualified watchmaker or the manufacturer. This watch has to have a pressure test to insure it's water tight. This may require replacement of some or all of the gaskets in the case.I would never recommend that this is something that you should try to do yourself.You would be amazed at the money I make do to improper replacement of JUST the battery.
Donald McPherson, Certified Watchmaker AWCI
www.finewatchmaking.com
WWW.AWCI.Com
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
SOURCE: I can't seem to set the time on my used tag heuer watch
Probably your watch has a screwdown crown and prior to attempt any
settings you have to unscrew it. Some peoples fingers are stronger then
others, so, try that with a pair of plyers. Cover your crown with a
soft cloth and then grip with plyers(this will avoid any damage).
Thread is right handed and unscrewing is done by turning the crown
anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS
If the watch is rusty, you can brake the crown off while trying to
unscrew it. Don't panic yet, as in this case you will need a watchmaker
anyway.
Don't forget to rate, please.
SOURCE: Tag Heuer Tiger Woods watch stops regularly
You should go back to the watch repair shop and ask for complete check-out of your watch. No watchmaker can return the watch to the customer without properly checking all the gearwork, timekeeping, battery power and all the features the watch has.
As your watch was serviced and the battery replacement took place, the executives of all the work done are responsible for all the faults your watch is having right now.
As watch repairs are quite expensive and time consuming, they (probably) will argue with you about this issue, but DO NOT give up, as these are YOUR consumer rights to ask for the job to be properly done (under warranty or paid by you). In case if you will be turned down, ask for FULL refund and find another shop.
If the repair shop is ready to undertake the job again, do not rush them, as the complete watch overhaul and check may take up to 6 weeks (this MUST be done at no any cost to you if you have the warranty or allready paid for the job).
P.S. I suspect that there is some fault in your watch geartrain, because if it is shooked or moved, the watch works, but when idle-it stops. That means the service of your watch was NOT DONE properly, and some failure or even dirt in geartrain was missed by the watchmaker (sometimes it happens- nobody is perfect!). This doesn't mean you have to agree with it, so, go and get your watch properly serviced and checked out.
Do not forget to rate, please.
