Question about Philips Televison & Video
TV keeps reverting to setup menu until warmed up then it does it occasionally
  • 734 Answers
If the TV is always on or in standby, it drives out moisture on the semiconductor circuits to keep it in good operating condition. Too many on/off, heating and cooling, is too much wear and tear.
Posted on Oct 15, 2010
Won't stay on channel. keeps reverting back to next lower channel.
Remove the batteries from the remote and see if the problem goes away, if so the remote has a bad button, that can possibly be fixed by cleaning it. Try these links:
The Remote Control Keypad Silicone Oil Problem
Cleaning Remote Control
How to Clean Remote Control
How to clean remote control
May 29, 2016 | Televison & Video
Autuotune samsung 42 inch plasma
please follow this step:
you have customized the picture and menu settings on your Samsung TV only to find that they keep reverting back to their default positions, this is because your unit is in what is referred to as "Shop Mode." This is the demonstration mode used by electronic retailers to show potential buyers all the features a Samsung television supports. Press the "Info" button on your remote control, and if under the "Picture Mode" heading it reads "Shop Mode," hold down the "Menu" button on the TV itself until the screen reads "Dynamic Mode." This has changed the picture mode to one of the pre-set positions. You may now change any settings you'd like.
God bless you
May 14, 2012 | Samsung 50 in. Plasma TV
After selection an input option the input menu stays up until you push "exit". Then it reverts to the tv input option canceling out any other menu selection. If you then try another route to get...
what has happened is there is a controller for menus and the selection of channel's av hdmi etcafter a hwile with some tvs they start to go on the blink it coud be worse i have had people with tvs that wont change channel keep jumping back and people without a signal atall the only thing you can do if it is unbearable is get the unit replaced or with some tvs a simple firmware update does the job as it resets everything but with most tvs the unit will need replaced it will cost no more than 100 dollars at a good tv repair store
Feb 26, 2011 | Vizio VX37L Television
RDR-GX315 was accidentally reverted to "Factory Settings" ... now we can get sound but no picture and progressive is turned on and we need to turn it off.
If your TV has progressive scan capability, you may be able to view the on-screen setup menu via the recorder - select 'SETUP' press 'ENTER' on your DVD recorder's remote to bring up the menu - with the remote arrow buttons, scroll down to select 'VIDEO' then 'PROGRESSIVE' - highlight it then set it to OFF (you cannot do this with a TV that does not support progressive scan from this unit). Once done, exit the setup menu and it should work fine with all the other settings. If your TV doesn't have progressive scan, connect the DVD recorder to one which does and turn its progressive output off there. I assume you still have the user manual for your recorder (if not, you can download it online for free as an Adobe document - .pdf. Page 73 details the setup steps for this model). I hope this tip helps somewhat.
Feb 11, 2011 | Sony RDR-GX315 DVD Recorder
How do I reset the 52" TV to original settings. Screen is on Widescreen permanently
Could you please post exact model of your sharp tv. however i will give you this generic solution. In order to do this, you'll need to have your remote handy. You cannot reset the television using the control panel.
  • Turn your Sharp television on. Press the "Menu" button on your remote control. Press the "Right" arrow until you see "Setup."
  • 2
    Press the "Down" arrow until you see "Reset" displayed under the Setup menu. Press "Enter."
  • 3
    Type your secret four-digit code using the remote keypad. If you do not know it, you'll need to reset it by following the process in the section "Resetting the Parental Control Password." After you type in the code, "Reset to Factory Preset Values" will appear on the screen.
  • 4
    Press the "Right" arrow to select "Yes" then press "Enter." The screen will show "Now TV Will Restart." Press the "Right" arrow then press "Enter." Wait for the television to reset and revert to the factory default settings.
  • Nov 14, 2010 | Sharp Televison & Video
    My tv keeps reverting to the Philips TV Menu
    If that TV has a 'menu' button on the front of the set, make sure nothing like coca-cola has spilled into where that switch is located. I would try a different remote in case the remote is getting flaky....
    Oct 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
    I can not find all the tv shows what do i do
    Channel Edit makes it easy for you to save or delete channels in the list of channels in the TV?s memory. 1. Using the Number buttons, select the channel you wish to save or delete. 2. Press MENU to see the menu. 3. Press upper or lower key to scroll through the menu until SETUP is highlighted. 4. Press right key to enter the SETUP menu. 5. Press upper or lower key to scroll through the SETUP menu until CHANNEL EDIT is highlighted. 6. Press right key to choose SAVED or DELETED. Choose SAVED to add the channel to the TV?s memory. It will be available using the CH +/? buttons. Choose DELETED to remove the present channel from the TV memory. To clear the menu press STATUS/EXIT. Or, wait a few seconds after you finish your adjustment; the menu will disappear automatically. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
    Jun 13, 2009 | Philips Magnavox 20MT133S 20" TV
    Samsung 933HD TV - Sound Switches On Automatically
    Seems like the auto upgrade in standby mode feature was the culprit.
    Switching this off from D MENU>SET-UP>SYSTEM>SOFTWARE UPGRADE did the trick.
    BTW my firmware version is T-TMDEUC-1003
    Nov 15, 2008 | Televison & Video
    Selected resolution will not save
    You need to change the setting in the Menu of ALL RESET from ON to OFF so that it will retain any setting changes that you make. To do this Press Ok button - right arrow to Mode Menu - down arrow to Setup tab - right arrow to All Reset - right arrow and choose Off and then press Ok. This will retain the mode setting until you manually change it again or change all reset back to On.
    Aug 21, 2008 | Olympus Camedia C-350 Digital Camera
    Televison & Video Logo
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
