Question about Toshiba Satellite Pro L300 Notebook
After turn on it is giving continue beep .No display.boot does not start.
  • 56 Answers
If you have a warranty on you laptop just go to the byer and solve .... if you dont then open the cover and take the ram of from the slot and clean and try ....
Posted on Oct 15, 2010
Acer Aspire 7720 beeps after awhile
If it continuously beeps after every while, must be you have some alert on software running on background, check , could be temp alert, or if you have any antivirus software, it also leads to beeping whenever it finds a virus(sometimes). Hope this helps.
Dec 15, 2013 | Acer Aspire 7720 Notebook
When i turn on my lenovo g585 lap it start with one beep and comes the display and go boot with continuous beep sound and stuck the lap
Hi...
Gives continuous beep sound , When my laptop switch on (Lenovo G585). No display but leds (power & battery) were blinking.
Sep 10, 2013 | Lenovo G585 Laptop
My pc beeps when stars and the does not start completly it continues to give that beeping and the monitor does not display anything
The beeps in your computer at boot up mean that there is an hardware.
Every number and lenght of beep is a code that indicates where the error is. You should refer to your producers webpage to "translate" the code in the cause of boot failure
Feb 06, 2013 | HP Computers & Internet
When i turned on switch dell vostro 230 it give no display and led colour is red
No Display, so does it seem like the computer booted up and is running except that the Display is black? Do you hear fans running, disk drive spinning, blinking lights or beeps?
I'm going to assume that in your case since you mentioned a red light that it is not booting up all the way. Therefore your problem is probably with the memory, the video card or some other motherboard issue.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 19, 2012 | Computers & Internet
No display and can not boot but gives 6 beeps when switched onthe first four are continuous and then two
1.power supply
2.memory cards
at last mother board need changing !
hope it will help
May 20, 2010 | Dell OptiPlex GX260 PC Desktop
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
Beeping before booting
probably the RAM. Take it out and put it back in to check. You will need some RAM to boot, so try each stick separately if you can. I'm guessing though that you'll have to get at least one other stick of RAM to check. You'll probably find that one is bad. It's probably covered for life, but that would be a good reason to upgrade it.
Nov 19, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
No boot up, display, beep, or HD action
I am having the same issue. Clearing/reset the bios will get the board to boot up, but when turned off and started again the board will not boot. you will have to clear the bios again. The board seems to be rebooting itself continuously before it evens get to the POST.
Jun 28, 2008 | EliteGroup P4M800PRO-M Motherboard
Toshiba Satellite Pro L300 Notebook Logo
157 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
