Question about Stairmaster 7000PT Nautilus Stepmill
It's making a grinding noise - Stairmaster 7000PT Nautilus Stepmill
  • Stairmaster Master
  • 918 Answers
This sounds like it could be a faulty transmission. You will have to remove one of the side panels in order to access the interior of the unit. Look in the bottom of the machine. If the seal in the transmission has failed, you will find a build up of oil in the bottom. If this is the findings, you will need to replace the transmission.
Transmission without Pulley and Drive Sprocket SM20001 SPORTSMITH net
Posted on May 21, 2014
Scooba 385 - Making Grinding Noises - Video I
there are no parts available for these ( toys ) so called vacuum cleaners. Sorry you wasted your money.
Oct 10, 2013 | iRobot Scooba 350 Robotic Vacuum
Grinding noise when starting '98 Izuzu Rodeo
Upload video please then i might have a better idea
Jul 15, 2013 | Cars & Trucks
Grinding noise when its in nuetral with engine running
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make grinding noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
These will help.
Thanks.
Nov 28, 2012 | 1995 Isuzu Pickup
2006 chevy cobalt transaxle noise , i blocked car up remove both front wheels started engine, engaged transmission to drive, listened to noise sounded a bit like a grumbling/grinding noise., no fluid leaks...
WORN FRONT BRAKE PADS WILL MAKE GRINDING NOISE IF PAD WORN DOWN TO RIVETS RUBBING AGAINST BRAKE ROTOR WILL MAKE GRINDING NOISE, IF BRAKE PADS OKAY WORN DAMAGE DRIVE SPROCKET SUPPORT BEARING .
Oct 25, 2011 | 2006 Chevrolet Cobalt
Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
Oct 18, 2010 | Xerox Phaser 6360DN Printer
Make noise when copying
dear u dont have mention the model and make witch some grinding noise or some other kide of noise if grinding there is any gear problem or if any other kine of noise may be any bushing dryed, other noise for the bearings in the heater unit i hope tis will help you
thanks
May 10, 2010 | Office Equipment & Supplies
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
97 blazer makes a grinding noise, I put it in 4 wheel and it stops making the grinding noise, I change the wheel bearing, and the u joints. Please help.
mine did the samething you have check if there is any transmission fluid in your transfer case. because i didn't and i put more in and the grinding went away.
Dec 04, 2008 | 1997 Chevrolet Blazer
Stairmaster 7000PT Nautilus Stepmill Logo
155 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
