Question about Dishwashers
I have a Kitchen Aid dishwasher model KUDP01ILBS1, and it's not draining completely at the end of the cycle. There is about an inch of water at the bottom of the washer. I did just replace the disposal, but connected up the washer drain tube to it just as it was connected prior. Can you please tell me what might be the problem?
  • 10,865 Answers
Hi Ben. Since you just replaced the disposal, begin by checking the entire length of the drain hose, from the drain pump in the lower front of the dishwasher to the disposal. If that hose is kinked, or has an extreme bend in it, that alone could be the problem. Joe
Posted on Oct 15, 2010
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
2-3 inches water left in bottom of dishwasher after it finishes it's cycle model DU81OCWDQ5
The model number of your dishwasher is DU810... (zero not O).
Please refer page 28 of user manual. It is normal for some water to stay at end of cycle. However, check if the air gap (if insalled) is clear. Also make sure the kitchen side of drain hose is clear.
Unless there is a fault condition shown by flashing lights, then it is pretty normal operation.
In case in future you need to refer to the parts of your dishwasher you can refer this site.
Jan 02, 2011 | Whirlpool Dishwashers
We have a Jenn-Air dishwasher. The water does not fully drain when washing cycle is complete. Roughly 1/2 to 3/4 inch of water remains. Any suggestions are appreciated.
Check the that the drain hose is not kinked in any way under the counter and leading to the garbage disposal. Also check that the port in the garbage disposal is not partially restricted, or that the kitchen drain is not slower than normal.
I had the slow drain issue recently, and it would take the dishwasher forever to complete a cycle.
Dec 17, 2009 | Kitchen Ranges
Water left in the bottom of a hobart (kit aid) dishwasher
Drain valve not opening, kinked or blocked drain hose. Remove the hose from the sink plumbing and look for debris. try running the drain hose into a bucket to eliminate a domestice plumbing issue, but hold onto it when it starts draining, or you will have a wet kitchen. Timer contacts may not be opening drain valve.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Kitchen aide won't drain
look in your air gap first make sure there is no debrie in there this will make you dishwasher drain really slow.
Jan 16, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Feb 21, 2008 | Dishwashers
Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Jan 25, 2007 | GE 24 in. GSD1000G Built-in Dishwasher
Dishwashers Logo
85 people viewed this question
Top Dishwashers Experts
