Question about Miele Novotronic T1570C Electric Dryer
My T1570 C dryer is leaking water. It's coming from the heat exchanger which is soaking wet. I cleaned it but the problem has persisted. I've checked that it is inserted correctly and closed. Often the red light and buzzer will come on that tells you to empty the water container but the container is always red hot and bone dry. I have the stackable washer/dryer and I did vaccum behind but I'm thinking something inside the hoses may be clogged. I also sometimes smell a burning smell but there is nothing clothes wise inside that could cause this and the stuff in the lint catcher by the door is moist instead of dry. Do I need to call a repair service or is there something I can do myself? I've looked through the manual and tried everything to no avail. I don't want to use the dryer at this point for fear of a flood or fire.
localwonder
  • 6784 Answers
SOURCE: When I put the dryer on it smells as if something
HI. You will need to make sure the dryer vent hose, as well as, the rest of the vent duct, is not clogged or obstructed. Unless regular maintenance is performed; chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified service tech perform this task. I am certain that your unit will need to be cleaned. The main target areas will be the blower housing and vent ducts.
Posted on Jul 02, 2010
heatman101
  • 43501 Answers
SOURCE: Hi, The clean air vent light came on and shut the
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Dryer is not getting hot
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 28, 2010
  • 4350 Answers
SOURCE: my brand newly installed dryer
Check that the smell is not coming from the washer, a VERY COMMON issue is the washer generates mold like smell, there is a cleaner that needs to be run through the washer every month. Not a detergent, but washing machine cleaner...
Posted on Aug 02, 2011
heatman101
  • 43501 Answers
SOURCE: there is a burned odor
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Posted on Sep 24, 2011
After every load, the dryer lint trap is wet and there's water condensation on inside of the glass door even days after use. I've thoroughly cleaned the ducts and the lint filter as well as inside where...
Is it gas dryer?
If it is might be problem with the heat exchanger, Water is one of the by products of combustion.
By chance do you have a Carbon Monoxide sensor?
Easy way to tell if a cracked heat exchanger is the problem.
Other thought I have is the dryer heating up when its drying, if the heater isn't working and you are throwing wet clothes in there that could be part of the issue.
a couple thoughts anyways
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Kenmore 7.3 cu. ft. Electric Dryer w/...
Solution for wet passenger side floor in Sonata 2011
Could be a quarter panel seal. I've seen a few where the leak is VERY hard to find.
Sep 24, 2012 | 2011 Hyundai Sonata 2.0
Water under and around dryer. Clothes dry but water on floor. The wash not leaking. I the vent and line are not clogged. What is causing the water under dry?
Unless the clothes are dripping, soaking, wet when they're put in the dryer (and it would take them a loooong time to dry if that were the case) there's bound to be a leak of some kind coming from somewhere other than the dryer. Do you have a lavatory or toilet on the other side of the wall behind the dryer? They dryer has no water of its own to leak.
Dec 27, 2011 | GE DBXR463EDWW Electric Dryer
I just found my floormats and floorboard soaking wet, can you explain?
on the passenger side? if it is the passenger side is your heat exchanger carrying the coolant that is used to regulate the cabin temperature. it is under the dash. Usually what happens is that the condenser (heat exchanger) the drain hose coming thru the firewall inside the engine compartment (passenger side) clogs not letting drain the water removed from the cabin during the AC cooling process. then the water start to bleed thru the joints of the box enclosing the heat exchanger. the solution is to blow or vacuum the protruding drain hose to clear the water path.
Now if the soaking carpet smell like coolant the problem is different.
Jul 18, 2011 | Hyundai Sonata Hybrid Cars & Trucks
Bosh axxis filter. how do i clean it? soap and
First of all the item I referred to in my question is actually a heat exchanger located below the dryer drum.
The maintenance man in the condo said remove it and clean it with soap and water. I did have a garden hose with a sprayer so I used the bath tube to give it a good cleaning.
It now looks clean and I cleaned the housing where this part is located with vaccuum and wet cleaning.
jtoolan 6-12-09 7:45 AM
Jun 11, 2009 | Bosch Axxis WTA4400 Dryers
Goodman leaking water from the sides what is going on?
could be the venting adapter which is abs plastic could be cracked or a hose came off inside the furnace which connects to the secondary heat exchanger or the heat exchanger is bad
May 02, 2009 | Goodman GMS90703BXA Heater
Burning smell coming from the dryer!
You have a serious clog somewhere in your dryer exhaust ventilation. I would recommend you STOP using the dryer immediately and clean both the interior and all the vent ducting from where it exits the dryer to where it exits the home. the burning is coming from lint build up in and around the heating element and its beginning to smolder. This is a potential fire hazard and may end up causing the heating circuits to fail. The condensation comes from the the inability of the hot air (which is mixed with humidity from your clothing) condensating inside the vent duct. The lint starts to collect and get wet to the point of saturation. Then it begins to cause water to form and leak out of the ducting and on to your floor. You do not want this condensation inside the dryer where the heating circuits are. The following link will provide with some guidance for future reference:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention the paragraph where it discusses proper dryer ventilation. I hope this helps you. Let me know if I can be of further assistance.
Sep 28, 2008 | GE DBSR453EBWW Electric Dryer
Wate rleak Miele premier 300
I have exactly the same problem with my new Miele washer dryer - and my kitchen is soaking wet. Have you found a solution ?
Jul 28, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic T1570C Electric Dryer Logo
75 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
