Question about Microtek Micro Test Pentascanner
I need a manual for any of these three Cable Testing Devices Microtest Pair Scanner, HP/Agilent J2177A, Black Box TS395A. They are all the same unit, so any manual will help.
How do i fix an error code 52.00 on laser jet hp 5033mfp
hey,
Its a scanner error - often these can be fixed.
The poster above forgot you have 2 scanners. Your error refers to the laser/scanner which is the unit that writes the information to the drum of the toner cartridge for printing. A bit different and a little harder to get to. The laser/scanner is the black box that sits above the toner cartridge on the frame and you have to remove the scanner/adf unit to get to it. The service manual has directions. When you remove the laser/scanner it you open the black box carefully you will see a chrome motor wheel towards the back that spins. Usually the shaft of that motor has become to tight with debris or other material and can not get up to speed. Sometimes there is a small clip that secures the motor in place and other times you can just lift up the chrome piece and it comes out. In either case you need to place one tiny drop of synthetic oil down the shaft of that motor, put the chrome piece back on, spin it a few times to make sure it is smooth and then put everything back together. It should then work. If not then the laser/scanner needs to be replaced. The first thing you will want to do is check the flat ribbon cable on the left side of the printer that plugs into the board. It will be the thinner cable.
This scanner error - often these can be fixed.
Click here the lick below to Download SmartPCFixer for Free to repair.
Fix PC Errors Optimize Your PC
May 27, 2015 | HP LaserJet Office Equipment & Supplies
THERE IS A LONG TIME AGO SINCE I DONT WORK WITH MY MICROTEST PENTASCANNER AND I DO NOT KNOW IF THE AC ADAPTER HAS AN OUPUT OF 9.VOLTS I AMP AC OR 9 VOLTS 1AMP DC PLEASE TELL ME WHICH IS THE RIGHT AC...
An AC adapter should output DC. The device should say next to the power plug what voltage input it requires. Also, check the AC adapter, it may say something like "Input 110-120VAC Output 9VDC".
Apr 26, 2011 | Microtest PentaScanner 350 (8180-00R)...
The printer is showing error 51 and not printing
Control Panel message
51 PRINTER ERROR
Description
Beam error
Action
Laser scanner cable connectors are faulty or laser scanner assembly is defective Most likly it is the laser/scanner assembly. The motor is probably not spinning at the right speed. You would need to find an old hp 4 no longer working and switch the laser/scanner. It is the "black box" located under the top cover. You would need to remove the right side cover, the top cover, the left side cover and the output assembly. Remove all the cables from the scanner retaining clips. Remove the three cables plugged into the scanner and remove the four screws attaching the scanner to the frame. When replacing the scanner make sure the shutter control arm on the left front side of the scanner is attached correctly so that the shutter closes when the toner cartiridge is removed. You could first try to remove the 3 connnectors and reset them.
Nov 17, 2010 | HP LaserJet 4 plus Printer
WE HAVE LOST OUR USER MANUAL AND NEED TO GET A COPY IF YOU CAN HELPUS THANK AND OUR BEST WISHES FOR A NEW YEAR 2010
Here are some information about your Agilent product. Copy this url to your internet browser navigation toolbar in order to view the contents.
1.)
http://cp.literature.agilent.com/litweb/pdf/5988-6816EN.pdf
2.)
http://www.aaatesters.com/Agilent_Wirescope_350_Singlemode_Multimode.html
3.)
http://www.home.agilent.com/agilent/product.jspx?nid=-536900888.536882829.00&cc=US&lc=eng
Suddenly in this site (3.) Selection & Configuration Guides is not available
Jan 11, 2010 | Agilent WireScope 350 (N2600A-100) Network...
I require the user's manual for an older Microtest MT350 Scanner
ftp://ftpboi.external.hp.com/ftp1/pub/networking/software/59636588.pdf
check on that it may be usefull.
Nov 17, 2009 | Computers & Internet
The LCD on mine, and its cousin, the Compass, has
Doesn't look like anyone has any ideas. I too have messed with connections but it looks like the ribbon cable and/or LCD need to be replaced. Of course nobody seems to carry these anymore
Oct 16, 2009 | Microtest PentaScanner 350 (8180-00R)...
Cannot upload tests from the scanner. Message says error 1/970 ?
Ww transferred the tests by groups to other folders, we then found the rogue test.
Nov 28, 2008 | Microtest OMNIScanner LT (8280-00) Network...
Omniscanner 2
Contat Elektrotech Ltd at sales@elektrotechltd.com who are specialist repair/service experts for the Omni Scanner
Mar 08, 2007 | Microtest Network adapter
Microtek Micro Test Pentascanner Logo
44 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Tony
shelmnot
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
