Question about Panasonic Portable Radio/Cassette Player
I have a Panasonic RX-F5 with a stuck tape, it will not reject or play.
3 Suggested Answers
  • 4234 Answers
SOURCE: cassettes tapes not moving in my Panasonic RX-ED77
If you can her the motor turning, there is a good chance that the belt(s) have broken and need to be replaced. If you hear nothing, then there could be a control issue. I'm leaning toward the belts though. Figure on $5-$15 for the belts,
Dan
Posted on Mar 18, 2009
HansPP
  • 2510 Answers
SOURCE: I own a Panasonic RX-ES20
The tape speed in governed by the capstan and the pinch roller - a thin silver pin and a rubber wheel about 3/4" in diameter. If the tape is not caught between the two, it will run at about the speed of the reels - fast, Check that the pinch roller moves up to the capstan pin when you select play. If it does not, there may be some tape jamming it or the arm may be bent or dislodged.
Posted on May 17, 2011
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
I require a user manuel for a Panasonic cd/double tape/radio model RX-ED70 EB-K FS61OE4750 CLASS 1 Panasonic Laser Product . Many Thanks for your help. bwesmith
You can get your manual for free from here:
http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/RX-ED70-_J
Enjoy
Aug 13, 2010 | Panasonic Audio Players & Recorders
My Panasonic pv-gs180 doesn't record.
If you have Head Cleaning Cassette play it at 10 seconds or use new Cassette for 10 minutes play or record. Otherwise Video Head damage
Mar 10, 2010 | Panasonic PV-GS180 Mini DV Digital...
How do I tape to tape
you mean to record?first,you must connect the other unit (if you are using two cassette)by using rca plug or earphone plugs.insert the plugs to audio in or aux(this is the unit that will record).if the other unit doesn't have the output audio,use the earphone out instead.time to record.the recorder must be set to tape/aux,(if you are using a unit with radio setting).then,push the play and record button at the same time.don't forget to put in the blank tape ok.then push play to the unit that you want to be recorded.the square symbol is for stop.the arrows pointing left ,rewind.pointing right, forward.the big arrow pointing right is the play and the button next to it is the record button.
May 14, 2009 | Panasonic RX-D29 Radio/Cassette/CD Boombox
Cassettes tapes not moving in my Panasonic RX-ED77
Dan
Mar 18, 2009 | Panasonic SA-XR55 Receiver
I have two different music systems, need answers for if possible,
On the no disc messages, try a cd or dvd lens cleaner which ever is appropriate for the device and also try blowing canned air inside, it can be a dirty lens.
Mar 13, 2009 | Sony Audio Players & Recorders
Door jammed open, no power
oN THIS VCR THERE IS 8SCREWS TO REMOVE THE COVER, REMOVE THE COVER CAREFULLY THEN PLUG THE CORD INTO THE WALL, THE CARRIAGE TRAY WILL ACCEPT OR REJECT THE CASSETTE. oNCE THIS PROCESS IS DONE AN THE CASSETTE IS REMOVED UNPLUG THE VCR AND REPLACE THE COVER WITH THE SCREWS
Jan 13, 2009 | Panasonic PV-V4540 VHS VCR
IT PLAYS TAPES SLOW
can i buy your panasonic rx-dt75. i have that model almost 15 yrs to me made in japan. but this past few months cd and tape do not work... contact me here +639392859269
Jan 06, 2009 | Panasonic Portable Radio/Cassette Player
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
R 0:00 -- can't play back tape
try to clean the video head...i advise to use a blank tape and fastforward it until the time code counter display...you should on it the menu of the camera..
Aug 05, 2007 | Panasonic PV-GS500 Camcorder
Panasonic Portable Radio/Cassette Player Logo
109 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
